Old 01-25-2014, 03:45 PM   #6
Originally Posted by Flipper_1938 View Post
I've thought about making my yaris think it is a toyota echo.....convert to throttle cable and non-abs brakes.
What all does the ecm control? ...what would you loose if you ran a yaris with the echo ecm?
The Echo is not CAN based, so you would have issues with the power steering, body ECU (door locks if equipped, door open status, etc.), and instrument cluster if you switched to a Echo ECM.
If there is enough interest and a commitment to the interest, I would be willing to develop the interface necessary to allow a cable throttle to work with the stock Yaris ECM.
body, cable, electronic, thottle
1.8L throttle body dimensions drawing CrankyOldMan DIY / Maintenance / Service 5 03-09-2016 09:30 PM
Cable throttle body Crazy Butcher Performance Modifications 23 01-24-2013 12:31 AM
Throttle Body spacer? jekqmb Performance Modifications 2 10-04-2011 11:02 PM
