Old 02-23-2011, 10:35 PM   #1
Brian
Brian's Avatar
My second retrofit
AP1 S2000 projectors
Reflector bowl
Lens trim
Shrouds
I still have a lot of work to do. Im in the process of making a .dxf program at work for a bracket to mount the projectors. There isn't enough room on the projectors to drill holes and put bolts through so the bracket will be attached where the two projector halves bolt together. The bracket will also have height and rotational adjustability for easy aiming. I'm hoping to have the bracket completed by monday. I'm still going to be running my 5000k bulbs and Denso ballasts. The complete inside of the headlights will be carbon fiber.
Old 02-24-2011, 12:39 AM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
Speechless, can't wait to see how is come out, good job brian.
Old 02-24-2011, 12:48 AM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Just my opinion but the reflector bowl shouldn't be CF. There's just too much CF going on. If it was matte black and the lens trim CF then it would be cool. My two cents.
Old 02-24-2011, 07:55 AM   #4
Brian
Brian's Avatar
I was thinking the same thing at first, but half of the bowl won't ever be seen because the projector and shroud will cover it. My headlights are satin black now so I wanted to do something completely different this time.
Old 02-24-2011, 02:11 AM   #5
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
I think it will look bad a$& when it all comes together. Great job and good luck :)
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Slick is offline   Reply With Quote
Old 02-24-2011, 04:02 AM   #6
boyer
boyer's Avatar
Drives: Vios/Yaris sedan
will be waiting for end result..
boyer is offline   Reply With Quote
Old 02-24-2011, 08:01 AM   #7
henry33
Drives: yaris1.33
wow looks great
keep us posted
henry33 is offline   Reply With Quote
Old 02-24-2011, 08:57 AM   #8
That's not possible.
Old 02-24-2011, 09:10 AM   #9
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
+1! That is going to look incredible when you get it done! Please update with more photos and an estimate of what you have invested.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 02-24-2011, 10:57 AM   #10
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Old 02-24-2011, 11:38 AM   #11
Brian
Brian's Avatar
Projectors + clear lens' - $370
Bulbs - $45
Pair of new headlights - $160
Ballasts (already have but new) - $165
Wiring harness - $30
Shrouds - $35
CF and supplies - about $100
A complete retrofit is not cheap and requires a lot of work.
Old 02-24-2011, 11:17 PM   #12
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Keep the pictures coming,this a great retro and having used the s2000 projectors in a few other builds I am curious to see how they fit in your build.....as for the CF.....that sir is gonna be really sweet when it is done.
Old 02-26-2011, 09:12 AM   #13
Brian
Brian's Avatar
Here is a trial set of brackets. I already know that they won't fit. The top slot will need to be moved up more and the bottom one down more. I'll use these to figure out the exact dimensons I need.
Old 04-03-2011, 11:14 PM   #14
Brian
Brian's Avatar
Update:
All of the cf work is done. I still might have to do some more trimming since these projectors are so big. Next step will be mounting/securing and aiming the projectors.
Old 04-03-2011, 11:16 PM   #15
big lo
big lo's Avatar
Drives: 2007 VIOS
awesome stuff Brian
TRD sportivo springs,Tokico Blue Shock/Struts,TRD rear sway bar & front bar,Tanabe engine bar,MI hoses (red), MI engine cover,SRI intake,VIOS vent visors,VIOS foglights,VIOS tails (HELLA lights & the Series 5 too),VIOS radio,VIOS badge,VIOS grill,18 inch R-1 rims wrapped in nankang tires 215/35-18z,chrome handles,retrofited the headlights, SHARK body kit (VIOS), Coming soon projectors heads with LED strip, Custom seats, MI hood lifts,MI momo steering wheel, sound system :)
Old 04-04-2011, 07:22 AM   #16
Aarron_M
Aarron_M's Avatar
Drives: 2011 Toyota Yaris
Wow. That looks great so far
Aarron_M is offline   Reply With Quote
Old 04-05-2011, 09:03 PM   #17
Brian
Brian's Avatar
Had another issue due to the size of the projector and shroud. The shroud was hitting the turn signal housing. I cut out the spot where the bulb attaches to the housing and moved it in a couple of inches. I also had to trim the turn signal housing and I'm in the process of rebuilding it so it's more compact.
Old 04-05-2011, 09:41 PM   #18
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Nice work! I admire your craftsmanship.
Retrofit & fogs big lo Cosmetic Modifications (Exterior/Interior) 0 06-19-2010 09:13 PM
My retrofit project Brian Cosmetic Modifications (Exterior/Interior) 39 05-30-2010 11:38 PM
Retrofit Question ChinoCharles Cosmetic Modifications (Exterior/Interior) 19 05-13-2009 06:20 PM
Sam's 2nd H.I.D. retrofit sam07yaris Photo-Video-Media Gallery 22 08-31-2007 04:02 AM
