Old 05-24-2013, 05:56 PM   #1
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
ATF Drain and Fill
My ,05 Yaris has 71k normal driving miles on it.
I noticed recently that it was shifting with just a very slight jerk.
Looking at the ATF color, showed it to be reddish brown, so I did a drain and fill.
When I looked in the drain pan I could see the the old ATF was a bit "muddy" in color, but the big indicator was the smell. I had a fairly funky smell to it.
2.6 qts of fresh ATF made a difference in the shifting. It is back to it's normal barely perceptible smoothness.
I know the CW is that Toyota WS last the life of the car, but I can't help but wonder what the old ATF would look and smell like at say 120k or greater and would it still be providing proper lubrication?
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
Old 05-24-2013, 07:07 PM   #2
I think lifetime AT Fluid is a bit of a stretch, potentially for the purpose of fudging the expense of ownership ratings for vehicles.
Old 05-28-2013, 05:46 PM   #3
Everglade
Crazy Russian
Everglade's Avatar
Drives: 2007 Yaris RS
I am in Vancouver, BC.
Bought 6 liters of Toyota ATF WS from stealership (around $7 per liter)
Warmed up the engine, drained.
Started the engine again and rolled gear handle from P to L and back a couple of times.
Drained around 3.3 litres of ATF.
Old ATF was a bit dark.
In a month gonna do another drain and refill to ensure ATF completely fresh.
Everglade is offline   Reply With Quote
Old 05-29-2013, 06:46 PM   #4
auxmike
auxmike's Avatar
I did this about a year ago. Buy 15 quarts. Yeah, its not cheap. I found exactly 3 quarts drained out every time I opened the tranny drain plug. I basicly drove my 40mi round trip to work and back and every afternoon when I got home drained out the three quarts. Did it 5 times and it was nice and red. Cheaper then a tranny failure or dealer visit... No way id leave it in there forever like the dipstick say...
Old 05-29-2013, 08:43 PM   #5
DMZ
DMZ's Avatar
I did it twice and it looks pretty good. I do it again next oil change. Then I should be good to go 'til about 160,000.
Yep, cheaper than tranny trouble and as very quick and easy to do.
Old 05-29-2013, 10:54 PM   #6
Everglade
Crazy Russian
Everglade's Avatar
Guess 2 times is enough ))
Gonna do another drain-n-refill tonight.
Old 05-30-2013, 10:32 PM   #7
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Is there a pan to drop? and a screen filter inside to clean?.
frog13 is offline   Reply With Quote
Old 05-30-2013, 11:01 PM   #8
Everglade
Crazy Russian
Everglade's Avatar
Yes, but you don't change the ATF filter every time you do a drain-n-refill.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Auto trans. drain and fill? FochMan DIY / Maintenance / Service 5 01-07-2010 11:41 PM
how much oil do i do i fill with? wholenizz DIY / Maintenance / Service 11 07-17-2009 09:52 AM
HELP! Gear Oil change on a sedan CASTREX DIY / Maintenance / Service 15 05-13-2007 04:14 AM
