Old 07-17-2013, 10:00 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Any way to add traction control?
I realize some yaris have TRAC built in, and some don't. I am wondering since it's the same ecm, is it possible to add traction control?
thanks
Old 07-17-2013, 10:44 PM   #2
The ECM and ABS ECU are different for the ones that have it. If you have ABS, you could add it by replacing those.
Old 07-17-2013, 11:01 PM   #3
caineroad
caineroad's Avatar
Oh.. it sounds it will be too expensive. I do have ABS.
I realized my car has no traction control when I could skid around in a gravel field with the front wheel spinning all over the place :p
Old 07-23-2013, 02:34 AM   #4
Astroman
Modded Moderator
Astroman's Avatar
Price it on ebay. Plenty of salvage yards selling them (although I didn't look into the cost.)
I would have never thought to ask such a question. Guess I assumed it was an added mechanical feature, so I learned something new about the Yaris today. Doesn't affect me as my '07 does not have ABS.
Old 07-24-2013, 11:08 AM   #5
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
I have an 09, any way to know if I have ABS or traction control?
Old 07-24-2013, 11:28 AM   #6
All US 09s have ABS. Traction control wasn't added until 2010.
Old 07-24-2013, 01:19 PM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
You would need the yaw (rotation around the vertical axis) rate sensor: http://www.villagetoyotaparts.com/pr...918052050.html
Looks like you need the steering angle sensor, too: http://www.villagetoyotaparts.com/pr...924552030.html
No idea if the wire harness on the 07-09 has a connector for those...
Old 07-24-2013, 03:16 PM   #8
That's right - The Yaw rate sensor and steering angle sensor are new pieces as well for the VSC.
Old 07-24-2013, 04:49 PM   #9
Shinare
Shinare's Avatar
Wow, now that would be some DIY... LOL ;)
Disabling Traction Control Aarron_M DIY / Maintenance / Service 7 02-21-2013 08:57 AM
Does traction control help in snow ? vector9mm General Yaris / Vitz Discussion 23 01-25-2012 11:41 AM
