![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Any way to add traction control?
I realize some yaris have TRAC built in, and some don't. I am wondering since it's the same ecm, is it possible to add traction control?
thanks |
The ECM and ABS ECU are different for the ones that have it. If you have ABS, you could add it by replacing those.
Oh.. it sounds it will be too expensive. I do have ABS.
I realized my car has no traction control when I could skid around in a gravel field with the front wheel spinning all over the place :p |
Modded Moderator
Price it on ebay. Plenty of salvage yards selling them (although I didn't look into the cost.)
I would have never thought to ask such a question. Guess I assumed it was an added mechanical feature, so I learned something new about the Yaris today. Doesn't affect me as my '07 does not have ABS. |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
I have an 09, any way to know if I have ABS or traction control?
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
All US 09s have ABS. Traction control wasn't added until 2010.
2ZR swap. DO IT! Ask how!
You would need the yaw (rotation around the vertical axis) rate sensor: http://www.villagetoyotaparts.com/pr...918052050.html
Looks like you need the steering angle sensor, too: http://www.villagetoyotaparts.com/pr...924552030.html No idea if the wire harness on the 07-09 has a connector for those... |
#8 | |
That's right - The Yaw rate sensor and steering angle sensor are new pieces as well for the VSC.
Wow, now that would be some DIY... LOL ;)
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Disabling Traction Control | Aarron_M | DIY / Maintenance / Service | 7 | 02-21-2013 08:57 AM |
| Does traction control help in snow ? | vector9mm | General Yaris / Vitz Discussion | 23 | 01-25-2012 11:41 AM |
