![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Ideas on an AT Temp Tap Location??
I'm installing a transmission fluid temperature gauge and I simply cannot figure out a place to place the sender unit. Originally, I was going to use the No.1 transaxle nut as shown on page 15 here:
http://etimago.com/yaris/repairmanua...0Transaxle.pdf, but the part I need basically doesn't exist. I ordered this (http://www.sunpro.com/product_detail.php?pid=16338), but it turns out I need an M8 x 1.0 (?). So uh, I can't find this anywhere online. I haven't bothered with auto / plumbing stores because apparently every store in the states HATES metric units. I was laughed at at Home Depot for even showing the balls to ask for something that isn't English units. ANYWAYS, I digress. Anybody have any ideas as to where I can place a sender unit? |
Bathroom + Laptop = <3
You should have told him that he worked at home depot and didn't know anything about the section he works in, because i am sure they must have had SOMETHING useful. Fastenal is where i usually go for anything hardware related.
Look into a tranny filter relocation kit if you can adapt one, no idea if you can. You can add a quart of extra oil and add whatever you need probably |
#4 | |
#5 | |
The fact that I need an adapter for an adapter makes my head hurt, lmao... I'm convinced you're either incredibly bright or I'm overwhelmingly stupid. Or both. Dunno.
CTScott, I am going to have this website renamed "CTScottWorld" as your reward for consistently being sooooooooo helpful
| Coolant Temp Sensor location? | Yeti | DIY / Maintenance / Service | 7 | 05-06-2009 10:13 AM |
| Inlet air temp vs. vehicle speed | LtNoogie | Performance Modifications | 8 | 04-27-2009 12:20 AM |
| outside temp on cluster??? | ae92trueno7 | Cosmetic Modifications (Exterior/Interior) | 11 | 01-01-2009 10:36 PM |
| diy factory aux location with aftermarked hu | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-28-2008 10:38 PM |
| Auto dim mirror with compass and temp | Violin | Cosmetic Modifications (Exterior/Interior) | 7 | 08-30-2006 06:48 PM |
