Old 12-08-2008, 09:58 AM   #1
iwantayarisnyc
Drives: 08 sedan auto
uhoh....valve tapping already????
just bought the car
and i swear it's already valve tapping already.....
and that's after the engine being warm
time to head to the toyota dealer?
iwantayarisnyc is offline   Reply With Quote
Old 12-08-2008, 10:03 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
loud injectors
Old 12-08-2008, 10:14 AM   #3
iwantayarisnyc
loud injectors
are you sure??? please i hope so. can i get another reader's opinion??
Old 12-08-2008, 11:06 AM   #4
its normal on newer toyota engines....they make a slight ticking
my xrs did it....yaris does it.....its nothing to sweat about
Old 12-08-2008, 11:57 AM   #5
Zefoxe
¦µ¶Œ€♦åËÆ⌐š└╘○Å╝◙þ·▲
Zefoxe's Avatar
Drives: Scion xD
Send a message via AIM to Zefoxe
I felt the same way. My brother said its the injectors, it seems the louder it is the colder it is outside :P
Coming 2010: Toyota iSt CK edition (CooperKiller) stay tuned
Zefoxe is offline   Reply With Quote
Old 12-08-2008, 12:08 PM   #6
TheSilkySmooth
TheSilkySmooth's Avatar
Car has mechanical tappet with a clearance so you will ALWAYS have valve noise. Car also has loud injetors - my wifes camry 2azfe was brought in for valve adjustment and it was just noisy injector. Let valvetrain wear in, its ALWAYS better noisy than tight. Just a note: cars will tend to stick valves during break in and you will get some noise until it clears. Please Leave the break in oil in for at least 2500mi - this oil has extra wear agents that your replacement oil will not have. It is great oil and should NOT be changed soon by worry wort. We have a inexpensive solid tappet cam and it need proper wear in. Your special break in filter will trap most all nasty wear items. Break -in runs about 15K miles if you look at UOA then wear tapers off to nothing. Dont worry this is not Kia or Mazda engine - it is quality motor with low oil consumption.
Old 12-08-2008, 04:24 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
don't be surprised if you throw a rod though..
Old 12-09-2008, 12:47 PM   #8
TheSilkySmooth
Somtime I like the rod thrown this way
Old 12-09-2008, 03:32 PM   #9
kou
Drives: 08 lb
in my opinion the plastic intake manifold is the main reason for hearing the noises of the otto cycle at work, if it was a solid cast piece it would be a much quieter engine.
Old 12-08-2008, 12:10 PM   #10
TheSilkySmooth
how many miles on it? Did you change oil yet? Dont beat it for 800 miles.
Old 12-08-2008, 02:07 PM   #11
iwantayarisnyc
the first oil change was actually done at 4998 miles, that's when the service light came on. (that's what the seller told me)
however, i bought it with 5000 miles.
i've driven only 100+ miles with it since
Old 12-11-2008, 12:56 PM   #12
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Not many miles..... common noise .......
That car has cost you a fortune so far!
Old 12-08-2008, 02:34 PM   #13
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Wow, there are like 3-4 threads on this. Please search and you will find that it is perfectly normal for this (and many other) Toyota engines.
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
WTB: Oil Control Valve/VVT Valve bdc87 Willing to Buy by private party 4 05-22-2009 08:15 PM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 12:34 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
