Old 04-18-2022, 10:24 AM   #1
bluefever00
Drives: 2008 Sedan
Front wheel bearing
I have a 2008 yaris without abs. I replaced a front wheel bearing 9 months ago with the beck/arnley one. It has failed 8,000 miles later. Would anyone happen to know if the abs one can be used for non-abs? The only non-abs one I see is the same one. The measurements look identical.
bluefever00 is offline   Reply With Quote
Old 04-18-2022, 05:04 PM   #2
Yes, you can use the bearing meant for an abs equipped model.
Old 04-21-2022, 03:19 AM   #3
toyotavios_11
Drives: Toyota Vios
get KOYO bearing rather than other
toyotavios_11 is offline   Reply With Quote
Old 04-21-2022, 07:38 AM   #4
esse10
Drives: 2009 yaris 2 door
bearings
how do you know the new bearing has failed already? what are the symptoms?
esse10 is offline   Reply With Quote
Old 04-21-2022, 09:40 PM   #5
remcafee
always get toyota parts if you can, they lastso much longer in my experience as a technician
Need front wheel alignment specs Rob888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-13-2023 11:00 AM
Need front wheel alignment specs Rob888 DIY / Maintenance / Service 1 03-05-2020 03:53 PM
Can't find front hub bearing assembly with ABS anywhere! PrettyWreckless DIY / Maintenance / Service 5 04-09-2018 03:15 PM
Mixing wheel sizes. front 195/60r15, back 195/65r15 (or viceversa) badillin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-04-2017 07:10 PM
10mm or 15mm wheel spacers for front wheels? b20vteg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2014 11:08 AM
