#19 |
#20 | |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
A belt tension gauge should be used to check the tension on the belt and to insure it is with in spec...
#21 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
where the belt is stretched between the farthest pulleys, push down on it it shouldn't move maybe 1/2" to 3/4" down ---any more and add tension...... |
#22 |
Vroom Vroom Beep Beep
My pump was $68. There are about $55 otherwise from Kragen/Schucks?checker or whatever the hell they are in your area. Mine is OEM replacement. The others are Cardone.
Ever blown out an R-200 diff god know's I have
#23 | |
http://www.trademotion.com/partlocat...05&catalogid=1 |
#24 | |
Peter.. Did you ever change out your water pump??...
#25 |
My water pump has gone out twice already i have 23k miles.
#26 |
The dealer actually notified me that mine was leaking when I went in to do that Seat belt tensioner recall. They covered it then (40,000 mi), not sure if i would be now(71000 mi).
#27 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
'easier' is not necessarily correct. same with bolt torque. if you do not have the correct tools, you have no business in the engine compartment (not -you-, I mean anyone) anyhow, water pumps do fail and they are easy to replace. they should last >180,000 though |
#28 | |
and my water pump hasn't had any problems yet, i have 50,000 miles on my car with the whole nst pulley setup (10 % underdrive crank, wp, alt.) |
#29 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
I have 81,000 miles and everything is stock on engine. Not had a problem with water pump yet.
#30 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
Your link:Water pump, xb 04-06 $92.34 $73.87 Unless the 7 is displayed as 5 on some computers
5% Tint Rear | Micro Image LED Ignition Light Kit |
#31 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Hey, is there a water pump lube from toyota or coolant conditioner to add at say 30k miles? - I hear all these problems are from the long life coolant. My Rav4 WP puked at 50k miles too ;(
#32 |
please sticky to DIY section.Thanks.
#33 |
![]() ![]() Drives: Meteorite Yaris Liftback Join Date: May 2007
I just had my water pump replaced today @ 33K miles. The car turns 3 years old this month. Kind of disappointing. The underside of my hood looked exactly as shown in the picture.
#34 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
Mine went out at 55k and other stuff is going out too such as my transmission leaking too!
#35 |
I think a Yaris is good but it doesnt appear to enjoy the stellar reliability of its forerunner the ECHO. Never heard of this wp issue with the ECHO and its even the same engine. Some have said the L life coolant is to blame. Does anyone know if any other Toyotas having wp issues? Wife has a Camry with 60k and so far so good.
#36 |
Mom's 2006 Corolla pump lasted 16k.
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 06:23 AM |
| DIY Requests. | TinyGiant | DIY / Maintenance / Service | 13 | 10-29-2008 10:39 AM |
