Old 03-09-2009, 01:44 PM   #91
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Job well done! Your car definitely whines. The S10 might hear it and back off.
Old 03-09-2009, 09:04 PM   #92
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Originally Posted by Doc Zaius View Post
Congrats on the install! I totally missed this... a lot can happen on YW when you've been away for the whole weekend. And I'm glad to see that your video fetish will finally be sated.
wow i missed this also. i was in baltimore seeing my favorite band play saturday night. and then slept all day sunday cuz i was out all night. congrats.
Well Noogie said that he left off Spacer B that is at the bottom of the blitz alternator bracket. We put it on and eyeballed it and the pulley from blitz did look out of line with the crank pulley. So we are taking off the spacer B and seeing if this works.
i just want to put this out there.
my yaris ate the first belt without spacer B because the alternator was out of alignment without it. i put the spacer on and the alternator sits straight up the way it should and will most likely not eat anymore belts since the spacer is on
Old 03-09-2009, 09:55 PM   #93
whooppee777
Ah! And possibly water/meth injection!? dun dun dun
lets clear something up.
MYTH: water methanol injection increases horsepower
FACT: water/methanol injection lowers inlet temperature allowing higher boost levels without the risk of detonation/knocking.
one problem. u cant re tune this kit to run higher boost
Old 03-09-2009, 10:12 PM   #94
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
The mystery of spacer B will never be understood.
Old 03-09-2009, 10:55 PM   #95
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
nice nice good job peterpoop! Enjoy the blitz!
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 03-09-2009, 11:08 PM   #96
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Yah, i forgot to update that. We ended up using the spacer B. It is aligned perfectly with it. But yah, our kits might all be different. I didn't have to file down the manifold to make it fit. I also was running the belt that came with the kit today and yesterday, but squeeking occurred today and i bought the correct belt. Going to install the NGK iridium spark plugs soon, then take some videos tonight!
Old 03-09-2009, 11:09 PM   #97
PETERPOOP
PETERPOOP's Avatar
Ah I seeee. I probably wouldn't have gone that route, but that is nice to know. I am just saving up for my new exhaust setup and I'll be a happy man.
Old 03-10-2009, 08:58 AM   #98
Jerkratt
Jerkratt's Avatar
unless u get a diff pulley... which icorrect me if im wrong NST makes or is making or will make :D
"It hurts more when its wet"
Old 03-10-2009, 10:45 AM   #99
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Nice Bro ! So was it worth the money/time???
Old 03-10-2009, 10:48 AM   #100
No, this is not going to happen. the Blitz kit has a clutch pulley that would be very difficult to reverse engineer. The other alternative is a fixed pulley, but then you very well might have tuning issues.
That leaves a slight overdrive crank pulley as a possibility, but again, possible tuning issues.
Old 03-10-2009, 01:05 PM   #101
PETERPOOP
PETERPOOP's Avatar
You know, I'd like a little more power. But who wouldn't, right? One could never be satisfied. But after knowing the power I've gotten with the blitz, I could never go back. So yes, worth the money/time. I just can't imagine how Garm's car would feel.
Old 03-10-2009, 03:44 PM   #102
Would the s/c guys go for an overdrive pulley? Is there room? Someone measure for that.
Old 03-10-2009, 04:05 PM   #103
kurokoma-kun
Drives: 2007 Yaris HB
How interesting, I was just discussing this with someone else.
How much enlargement is needed to see the benefit? I've seen overdrive pullies for the Mini that are just +2%...
There's less than a finger's width of clearance between crank and w/p pullies on the yaris--don't think that's enough?
I use my stock crank pulley as a paperweight however, I'll measure it tonight
Old 03-10-2009, 05:13 PM   #104
That is probably too close to do anything good with, unless a smaller w/p pulley was included.
OR, you could remove the w/p pulley and go with an electric water pump, but then you have a project on your hands...
Old 03-10-2009, 05:17 PM   #105
Jerkratt
Jerkratt's Avatar
^ hint hint lol
Old 03-10-2009, 05:26 PM   #106
kurokoma-kun
Hmmm, electric alternator too? Anything to be just like you Garm... as in finally rid of that stock ECM! It's full of sorcery
Old 03-10-2009, 05:44 PM   #107
Yes -- I have snuck up on my car at night a few times and witnessed the eerie green glow from the ECU.... wonder what (or who) it is communicating with?
Old 03-10-2009, 06:40 PM   #108
NonStopTuning
Garm and I have chatted about this a couple times. And where there is a will, there is always a way. We have worked around such limitations in other SC Toyotas in the past. Think late 80s Toyota MR2 SC.
The dilemma we have has been the same one we have had since day one. We need someone with a SC Yaris, with the ability and willingness to test a pulley for us, and get some extensive dyno data with the stock pulley and any test pulley we offer. We have not had any serious takers.
You all know my phone number, my screen name, and my Email address. I am ready to chat whenever you guys are.
MIKE @ NST
www.NonStopTuning.com
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
BLITZ supercharger kits IN STOCK cali yaris Micro Image 34 06-02-2012 10:31 AM
anyone with Blitz supercharger? yrsdrgn Performance Modifications 52 08-24-2010 07:57 AM
Blitz Supercharger vendors sdyaris Forced Induction Forum 32 09-18-2009 12:28 AM
blitz supercharger!!! djgab101 Australia 4 11-20-2008 05:06 AM
