Old 05-23-2010, 09:50 PM   #37
PhillyG
Drives: 2009 Yaris
Originally Posted by YarisGoFar View Post
I installed it on my 2010 3 LB MT today. I decided to go with the factory steering wheel cover rather than drilling my own hole on a car that has less than 3k miles on it.
AMen Brother! that is why i am waiting on my parts to arrive! even with only 9k on mine... worth it to me to have it factory looking if i ever do have to take it to the stealership!
PhillyG is offline   Reply With Quote
Old 05-26-2010, 04:38 PM   #38
PhillyG
Drives: 2009 Yaris
got my parts! did the install! looks factory! it works! many thanks to everyone!
Old 05-26-2010, 05:19 PM   #39
Revsson
Congratulations!
Old 05-27-2010, 07:20 AM   #40
YarisGoFar
Drives: '10 Yaris 3Dr LB, MT Meteorite
Congrats! Boy did I miss cc. My 90 mi round trip commute up and down the interstate is soooo much easier!
YarisGoFar is offline   Reply With Quote
Old 05-30-2010, 03:13 PM   #41
Soner
Send a message via Yahoo to Soner
This question is for everyone who installed the cruise control. How did you guys remove those screws that is removed by using the #27 torx? Those screws are so tight it is impossible to loosen them.
On DIY it's not even mentioned how to take the steering wheel apart other than use #27 torx to remove the airbag. I guess no one else had this problem. Parts of my palms are all red b/c of forcing it too much. Am I doing something wrong?
Soner is offline   Reply With Quote
Old 05-30-2010, 09:26 PM   #42
On my 09 the airbag screws came off easily with a 1/4" drive socket torx bit. I initially tried the torx bit with a screwdriver, but couldn't break them loose. The extra leverage of the 1/4" ratchet was more than enough.
Old 05-30-2010, 09:43 PM   #43
Soner
Can you put a picture of the part you are talking about? When I googled it, I couldn't figure out how I can use it together with the #27 torx I got from Sears.
Old 05-30-2010, 10:44 PM   #44
Old 05-30-2010, 10:47 PM   #45
If you bought a T27 1/4" screwdriver bit, you can make a DIY version of the above, by sticking the bit in a 1/4" socket and wrapping it with tape so it doesn't just fall out.
Old 05-31-2010, 01:27 PM   #46
Soner
OK thank you very much. Let me try that.
Old 06-01-2010, 08:21 AM   #47
PhillyG
Drives: 2009 Yaris
i used a socket torx bit... just what i had.. worked great.. as for remvoing the steering wheel... once you have the airbag out of the way.. and MARKED the alignment of the wheel and post... i just wiggled gently but firmly (dont damage the clockspring) and the wheel came loose with only a minute of wiggling.
Old 06-11-2010, 09:05 AM   #48
PhillyG
Drives: 2009 Yaris
just got back from a trip to florida.. cruise is fantastic.! worked flawlessly
Old 06-18-2010, 02:35 PM   #49
CB900F2
Drives: 08 Sedan
Hye guys... I want to install the CC on my 08 CND Sedan and I am wondering if anyone has a template as to where to punch/cut the hole for the stalk on the cover?
My wife would be very upset with me if I make a bo bo
thanks guys!
CB900F2 is offline   Reply With Quote
Old 06-18-2010, 03:06 PM   #50
I purchased my stalk off ebay along with a Scion Tc steering wheel.
This is what the OEM hole looks like:
There was a rubber bushing that mounted over the fins, which fit tightly around the stalk and flexed as the stalk moved:
I mounted the bushing to my rear cover and then used the center of it as my drill guide (I drilled a 1" round hole, rather than trying to duplicate the square one:
Before I installed the bushing I scanned it. Here's a PDF of it. Print it without scaling and it will print a perfect one. You can either cut one out of rubber, or just use the paper one as your template:
Cruise bushing.pdf
Old 06-18-2010, 10:03 PM   #51
Revsson
Hmmm....first mistake, it's boo-boo!
http://dictionary.reference.com/browse/boo+boo
CTScott is the man...he'll get you all kinds of info.
Old 07-02-2010, 02:22 PM   #52
2009BBPliftback
2009BBPliftback's Avatar
In the garage doing this as we speak! I have a 2009 lb with conv package I hope all the wiring is in place from CTscotts chart he made looks like I will be good to go. let you know in a few!
2009BBPliftback is offline   Reply With Quote
Old 07-02-2010, 02:58 PM   #53
2009BBPliftback
just finished installing the cruise on my 09 liftback stick with conv package no power windows/locks everything works great! thanks to all the guinea pigs and Sparks Toyota for the good price on parts!!
Old 07-05-2010, 10:44 AM   #54
dbielawski
Drives: 07 Yaris
thanks guys!
See http://www.trdsparks.com/install/000...8Yarisinst.pdf
I am waiting for the parts and plan to install as soon as possible on my 07 sedan.
dbielawski is offline   Reply With Quote
How difficult is it to install the aftermarket cruise control kit? grampi Performance Modifications 3 07-19-2007 08:06 AM
