My second retrofit
AP1 S2000 projectors
![]() ![]() ![]() Reflector bowl ![]() ![]() Lens trim ![]() Shrouds ![]() I still have a lot of work to do. Im in the process of making a .dxf program at work for a bracket to mount the projectors. There isn't enough room on the projectors to drill holes and put bolts through so the bracket will be attached where the two projector halves bolt together. The bracket will also have height and rotational adjustability for easy aiming. I'm hoping to have the bracket completed by monday. I'm still going to be running my 5000k bulbs and Denso ballasts. The complete inside of the headlights will be carbon fiber.
Speechless, can't wait to see how is come out, good job brian.
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Just my opinion but the reflector bowl shouldn't be CF. There's just too much CF going on. If it was matte black and the lens trim CF then it would be cool. My two cents.
I think it will look bad a$& when it all comes together. Great job and good luck :)
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
will be waiting for end result..
I was thinking the same thing at first, but half of the bowl won't ever be seen because the projector and shroud will cover it. My headlights are satin black now so I wanted to do something completely different this time.
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
wow looks great
keep us posted |
#8 | |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
+1! That is going to look incredible when you get it done! Please update with more photos and an estimate of what you have invested.
#11 | |
Bulbs - $45 Pair of new headlights - $160 Ballasts (already have but new) - $165 Wiring harness - $30 Shrouds - $35 CF and supplies - about $100 A complete retrofit is not cheap and requires a lot of work.
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Keep the pictures coming,this a great retro and having used the s2000 projectors in a few other builds I am curious to see how they fit in your build.....as for the CF.....that sir is gonna be really sweet when it is done.
Here is a trial set of brackets. I already know that they won't fit. The top slot will need to be moved up more and the bottom one down more. I'll use these to figure out the exact dimensons I need.
#14 |
Update:
All of the cf work is done. I still might have to do some more trimming since these projectors are so big. Next step will be mounting/securing and aiming the projectors. ![]() ![]() ![]() ![]() ![]()
#15 |
awesome stuff Brian
#16 |
![]() ![]() Drives: 2011 Toyota Yaris Join Date: Mar 2011
Wow. That looks great so far
#17 |
Had another issue due to the size of the projector and shroud. The shroud was hitting the turn signal housing. I cut out the spot where the bulb attaches to the housing and moved it in a couple of inches. I also had to trim the turn signal housing and I'm in the process of rebuilding it so it's more compact.
#18 |
Not quite a noob
Nice work! I admire your craftsmanship.
| Retrofit & fogs | big lo | Cosmetic Modifications (Exterior/Interior) | 0 | 06-19-2010 09:13 PM |
| My retrofit project | Brian | Cosmetic Modifications (Exterior/Interior) | 39 | 05-30-2010 11:38 PM |
| Retrofit Question | ChinoCharles | Cosmetic Modifications (Exterior/Interior) | 19 | 05-13-2009 06:20 PM |
| Sam's 2nd H.I.D. retrofit | sam07yaris | Photo-Video-Media Gallery | 22 | 08-31-2007 04:02 AM |
