![]() Drives: 2008 Yaris Hatchback Join Date: Dec 2011
08 HB DRL Issue
Model: 08 Yaris Hatchback
....after a while searching on Internet, I end up here, it seems you guys are so professional... plz help.. with my issue of the DRL that I tired to put at the position of the fog light What I tend to do:: The negative wire need to connect to the negative side of battery. The positive wire need to get power from the ignition fuse box. Therefore, the Daytime Running Light will turn on when the key ignition on. The above is what that eBay seller says... and I want the DRL runs only after Headlight is on or always on after I start the engine... What I did:: Tap DRL negative wire to (-) on battery, then bought a Fuse Tap replacing the headlight fuse, connected DRL positive wire to Fuse Tap Issue 1::Replace LEFT headlight fuse with fuse tap, the DRL is only turned on when I switched to parking light, but will be off when headlight is on...this is what i don't want.. Issue 2::Replace Right headlight fuse with fuse tap, the DRL is always on after I replace the fuse with fuse tap, no matter the I put the ignition key in or not... sad.. Issue 3:: If I tap the DRL positive wire to (+) on Battery, negative to fuse tap... it starts blinking/flashing.. so what should I do? ![]() |
The problem is that the headlight fuses are constant power supplies. The ground leg is the switched side for the headlights. So, you would connect the positive leg of your DRLs to the battery (with a fuse) and then connect the negative to the switched ground leg on the headlight connector, which is the blue wire on the right headlight and the green wire on the left headlight.
i am a totally newbbie here. .. wheres the switched ground leg or where is the headlight connector? are these in the fuse box? thanks
Switched ground leg is not a where, but rather a what. Some cars switch the positive feed to the bulb, some like ours switch the ground.
The headlight connector is the three pin connector that plugs into the back of the headlight bulb.
| DRL to city/aux fog/LED | dean_park | DIY / Maintenance / Service | 9 | 09-13-2010 10:03 AM |
| Hid bi xenon problem need to keep drl due to fogs | marcus | Cosmetic Modifications (Exterior/Interior) | 4 | 06-20-2010 12:01 PM |
| DRL in Yaris from...? | Falconia | General Yaris / Vitz Discussion | 3 | 02-25-2010 01:22 AM |
| Disabled drl and installed hids and now no fogs... | 604yarisrs | Cosmetic Modifications (Exterior/Interior) | 10 | 02-14-2010 12:26 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
