#991 | |
play every day
![]() At least it worked right for one person here. I'm also glad it worked with your SRI so I can rule out that variable on mine. I can say that when you step on the gas... man, it roars! ![]() The noise could be deceptively making the car feel like it's faster, but the dyno will provide an objective answer that. Even if all of the issues aren't sorted out, when I get the ECU to a stable point, I'm taking it down to Harry's dyno shop! Greg |
#992 |
I don't remember if it was asked at all, but does this manifold sit any closer to the rad than the plastic one?
#993 | |
play every day
#994 |
play every day
It was the IDLE.
![]() This morning, I cranked the screw out one full turn and did a cold start. Didn't even reset the ECU. NO CEL light. Totally normal start. No racing idle. No hunting for idle speed. Perfectly normal warm up idle. Totally normal hot idle. No surging. No sudden shuddering notch from slight throttle to decel... ...and the throttle response is SUPERB. (oooh, goody )So the problem was that the ECU couldn't function properly because the butterfly was being physically prevented from being closed enough by the idle screw which was factory set for a 1.8 and not a 1.5. I can't tell you how happy this makes me to have found out how to instantly solve all of the problems with just one simple procedure. It was really dicey breaking loose the idle adjustment screw without stripping it. I used a fractional inch hex key as it was slightly larger than the metric one, and applied Liquid wrench to the threads. Then I put in the hex key and tapped it with a mallot. It turned really hard right at first and then was much easier as the oil penetrated the threads. Now it twiddles without being loose. I'm going to set it with silicone so that if I ever need to readjust it, the silicone plug can be removed easily. Dyno shop, here I come!
#995 |
#996 | |
#997 |
play every day
#998 |
play every day
I combined the Simota intake tube with the BLOX velocity stack because the Simota is larger in diameter which matches the larger diameter of the Corolla throttle body throat...
![]() Now no adaptor coupling is needed, as everything is all the same size straight through from the velocity stack to the throttle body... ![]() ![]() Notice the throttle body?... you'd never know that was an 8 year old junkyard part. Stainless steel micro bead blasting makes the old casting look like it's brand new. I think I'll go for a ride now.
#999 |
![]() Drives: 02 Yaris 1.5 T-sport Join Date: Dec 2012
Glad to hear you got it running sweet!
cant wait for the dyno!
#1000 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
That's awesome you got it all straightened out. I wanted to adjust the idle screw on mine, but it didn't bother me enough to go out of my way to take the time to do it. Now I kind of wish I had...however, I agree, the throttle response is AMAZING! My fiance, who used to have a Yaris, even commented on the difference it makes!
Can't wait to see what the dyno puts down for you!
#1001 | ||
play every day
![]() I can't believe that it works so much better than the stock throttle body. Especially in low rpm response. You barely touch the pedal and the car is right up to speed. Haven't taken it on the freeway yet, but I'll do that tomorrow. It's all gassed up and ready to take mileage readings. Quote:
![]() Now the 1.8 throttle body matches the 1.8 manifold as well as the oversized SRI. |
#1002 | |
play every day
#1003 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
#1004 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
No dude, THANK YOU!!! I am so happy you got it running good finally, and that there seems to be a noticeable difference. Looking at the two throttle bodies side by side, you would think there would have to be. The stock TB is so small!
Anyways, this has been a great thread to follow, and I know I can speak for the entire community when I say thanks for posting so often and clearly about the issues and wins you have been having. These threads help us all out. Again, congrats, and I can't wait to see what this sucker does on the dyno. Please post a vid with audio! I bet she screams! |
#1005 |
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
Staring at pic............................................... .................................................. .................................................. .................................................. .................................................. .................................................. ...........still staring at pic............................................... .................................................. .................................................. .................................................. .......damn nice.............................................. .................................................. .................................................. .................................................. .......still staring.
Why strive for a JDM BB, when you can promote the Scion badge? |
#1006 | |
play every day
![]() From this experience I'm pretty certain that the chips don't even need to be swapped. The butterfly just needs to close farther so that the ECU can find the right idle. Because when I ran both chips, both had the same symptoms. Reducing the idle speed alone is what resolved all of the issues. So in the future... If anyone wants to install a part number 030 Corolla 1ZZ throttle body on their 1NZ engine, don't mess with the chips, and simply turn the idle down by backing out the little idle adjustment screw counterclockwise one turn using a 5/64th inch hex key... and everything should work just fine. I did quite a bit of driving today on the freeway and in traffic with shopping and running errands, and I'm so thoroughly pleased with how well the engine responds with the bigger throttle body. It behaves like a completely different car!
#1007 | |
#1008 |
play every day
Well... maybe.
![]() Although hybrids use an Atkinson cycle engine which is quite different from regular Otto cycle engines. Atkinsons fire once per revolution, whereas Ottos fire once for every two revolutions. So this means that your ECU likely has totally different running parameters seeing as the engine spins the generator to charge the batteries. That completely different style of intake manifold is the tipoff. It looks like it is made to operate optimally in a very narrow rpm range. The bolt spacings are: 67mm 71mm 76mm They'll also need to be in the right orientation and not flipped over. So if the 76.. is on the right and in a vertical position, the top left will be 67mm and the bottom left will be 71mm like this... ![]() See if they match yours.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
