Old 12-31-2012, 04:30 AM   #11
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Originally Posted by tooter View Post
I don't think I'll be dynoing it with a 1ZZ as I'm more of an economy driver than a performance one. The manifold is not only designed for the 1ZZ throttle body, it was also designed for a 1.8 engine so I don't think it would make that much difference in an normally aspirated application. However, a forced induction situation would be a completely different story. Even at the tooter's best +4hp at 5,600rpm that isn't nearly enough to be detected in actual driving. And remember that's at wide open throttle. Most driving is at partial throttle, where the difference between the tooter and stock manifold is too slight to feel. We've been running it on our daily driver Yaris for over 2,000 miles now and it works just fine. And the stock air box really quiets down the intake.
You're killing me here, man. You've come so far that not sourcing a 1ZZ TB and dynoing it seems weird to me, like you're aborting the project early. You even had the TB adapter made to match the 1ZZ throttle body, yet you aren't going to at least try and get one?
4/20 NEVER FORGET is offline   Reply With Quote
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
