Old 01-03-2013, 11:41 AM   #11
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Originally Posted by tooter View Post
Ok, I'll get one and dyno it even though that wasn't the goal.
Making the tooter fit both throttle bodies without any extra parts was an afterthought so that I wouldn't have to stock 2 adaptors. In fact it actually fits three, the stock 51mm three bolt cable controlled throttle body.
I still think that the results will be similar as these back to back runs (stock:red tooter:blue) done on the same day...
Back when I worked on Hondas, when we would swap intake manifolds, whenever possible we would include whatever the largest stock throttle body that would fit the manifold. I think we have a similar case here, while not a huge bottle-neck, it's a bottle neck to the system, and you did make the adapter to fit the larger throttle body.
I'm sorry if I came off harsh at all in my last post, I've enjoyed this thread and your tinkering that has led you to where you are. It's a good looking manifold, and it was designed for a larger throttle body than that which you are using, and it's an easy swap to the larger 1ZZ. You have to at least try :) I think there are many others who are following the thread that are also very interested. I think with the change will come more tinkering, and more content too. I appreciate the informative posts.
4/20 NEVER FORGET is offline   Reply With Quote
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
