Old 01-08-2013, 02:04 PM   #1
No one listens to me. I sold at least five pre-swapped TB's and none of my customers had issues. Swap the chip.
Old 01-08-2013, 02:08 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Got it, Garm.
Old 01-09-2013, 11:22 PM   #3
tooter
play every day
tooter's Avatar
Hey Garm,
Swapped out the chips and the throttle body does work a little bit better. It only goes to 2,000 now while suddenly deciding to hunt around for an idle speed. And it still has that 2 second delayed jerky drop on decel that makes the drivetrain shudder. I did turn the idle down 1/4 turn. It needs more, but at least I can do something about that issue.
Driving at speed is strange, you just rest your big toe on the accelerator and it holds 40 mph Even partial throttle and the engine is eagerly accelerating. Clearly this thing is capable of feeding lots of air into the engine without hardly any angle on the butterfly. This makes the throttle extremely sensitive. Now that's not a complaint as it's not so much so as to be unsafe. It will just take some driving to get used to it.
All in all, at least some improvement. Do you have any other ideas? Particularly about the two second delay of the jerk on decel. If I just barely have the throttle pressed, the jerking cycles back and forth constantly. It feels like it has lost the ability to smoothly transition from throttle to decel, and the delay tells me that it is computer related because it is so perfectly evenly timed.
Even running both chips the throttle body has never thrown a CEL light... so at least that's good.
Greg
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 02:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 08:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 07:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
