Old 01-09-2013, 06:27 PM   #973
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by bladesmith6 View Post
I swapped the chip on the tb I had and still had issues. The high idle finally came down a bit but when you let off the pedal to decel the car got kind of herky-jerky(bucked) I finally took it off because of that. You could feel that the acceleration was better though....
I hear ya on the bucking... it's flat out undriveable.
I'm swapping out the chip right now and am going to also turn down the idle, and will see what happens.
Old 01-09-2013, 10:22 PM   #974
tooter
play every day
tooter's Avatar
No one listens to me. I sold at least five pre-swapped TB's and none of my customers had issues. Swap the chip.
Hey Garm,
Swapped out the chips and the throttle body does work a little bit better. It only goes to 2,000 now while suddenly deciding to hunt around for an idle speed. And it still has that 2 second delayed jerky drop on decel that makes the drivetrain shudder. I did turn the idle down 1/4 turn. It needs more, but at least I can do something about that issue.
Driving at speed is strange, you just rest your big toe on the accelerator and it holds 40 mph Even partial throttle and the engine is eagerly accelerating. Clearly this thing is capable of feeding lots of air into the engine without hardly any angle on the butterfly. This makes the throttle extremely sensitive. Now that's not a complaint as it's not so much so as to be unsafe. It will just take some driving to get used to it.
All in all, at least some improvement. Do you have any other ideas? Particularly about the two second delay of the jerk on decel. If I just barely have the throttle pressed, the jerking cycles back and forth constantly. It feels like it has lost the ability to smoothly transition from throttle to decel, and the delay tells me that it is computer related because it is so perfectly evenly timed.
Even running both chips the throttle body has never thrown a CEL light... so at least that's good.
Greg
Old 01-09-2013, 10:30 PM   #975
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If you remember the old fashioned fueling devices called a carburetor, they had a device called a dashpot that holds the throttle partially open while you release the pedal and acts as an emission control device. The computer treats the electronic throttle the same way. But because the throttle is larger the effect is greater.
Old 01-09-2013, 10:35 PM   #976
tooter
play every day
tooter's Avatar
Originally Posted by TOLMACH View Post
Thanks
Have not yet received my adaptor.. but I am sure it is totally awesome ))
Wow... it's been 7 days since it was mailed. How long does it take stuff to go through customs? The Customs Declaration number is:
LC892190662US
It's a Small Flat Rate Priority Mail Box. See if they can locate it.
Greg
Old 01-09-2013, 10:38 PM   #977
tooter
play every day
tooter's Avatar
Yeah, I'm familiar with those, because I'm from that era.
...but they let the throttle down slowly and smoothly. This waits 2 seconds and then suddenly drops it shut. This is a precise computer timed event as it does it exactly the same each time.
So this brings me back around to the same question:
Has anyone here ever successfully run a Corolla throttle body with none of the issues I'm experiencing?
Old 01-09-2013, 11:32 PM   #978
bladesmith6
Drives: 2007 yaris HB
You know i was thinking about this , this might be the case where one of those aftermarket throttle controllers is just the thing. You have to calibrate them when you plug it in between the accel pedal and the obd II port anyway, it might correct the bucking issue...
bladesmith6 is offline   Reply With Quote
Old 01-09-2013, 11:37 PM   #979
tooter
play every day
tooter's Avatar
Now that's an intriguing idea.
Does anyone here run a throttle controller that they can program for instant deceleration?
Old 01-10-2013, 07:13 AM   #980
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
From what I remember reading in other TB swap threads, you need to let the ECU completely reset between idle screw adjustments--i.e. unplug the battery for at least a few minutes. In theory, that will help with the idle RPM hunting.
Old 01-10-2013, 09:42 AM   #981
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
As mentioned, aside from the fluctuating idle at cold start (which only lasted 1-2 minutes) I had ZERO problems with mine. Also had an SRI on it. Same part number as yours, just cleaned it up and slapped it on. No chip swap. Didn't even clean the epoxy off the idle screw.
I'll do some digging to see if I ever did a video of it.
Old 01-10-2013, 09:50 AM   #982
Tooter has a 2012, which has an entirely new ECM, so there may be some differences in how the ECM reacts to changing the throttle controller.
Old 01-10-2013, 12:29 PM   #983
tooter
play every day
tooter's Avatar
I'll still try Cranky's advice (Thanks! ) of resetting between each idle change. I'm really going to crank it down today, because regardless of any of the other issues, it idles too fast. I was thinking that maybe the ECU keeps fishing around for the right idle speed, because the butterfly is prevented from closing enough to acheive it.
Old 01-10-2013, 12:43 PM   #984
tooter
play every day
tooter's Avatar
I'm glad to hear that,sucker...
At least it worked right for one person here. I'm also glad it worked with your SRI so I can rule out that variable on mine. I can say that when you step on the gas... man, it roars!
The noise could be deceptively making the car feel like it's faster, but the dyno will provide an objective answer that.
Even if all of the issues aren't sorted out, when I get the ECU to a stable point, I'm taking it down to Harry's dyno shop!
Greg
Old 01-10-2013, 12:45 PM   #985
Bluevitz-rs
I don't remember if it was asked at all, but does this manifold sit any closer to the rad than the plastic one?
Old 01-10-2013, 01:26 PM   #986
tooter
play every day
tooter's Avatar
Just measured. The minimum distance between the tooter and the plastic radiator reservoir is 30mm. This is the the point where it comes closest to the radiator assembly. It's not nearly as compact as the stock manifold because the runners are larger diameter and curve around a lot so that they will all end up being exactly the same length.
Old 01-10-2013, 02:38 PM   #987
tooter
play every day
tooter's Avatar
It was the IDLE.
This morning, I cranked the screw out one full turn and did a cold start. Didn't even reset the ECU. NO CEL light. Totally normal start. No racing idle. No hunting for idle speed. Perfectly normal warm up idle. Totally normal hot idle. No surging. No sudden shuddering notch from slight throttle to decel...
...and the throttle response is SUPERB.
(oooh, goody )
So the problem was that the ECU couldn't function properly because the butterfly was being physically prevented from being closed enough by the idle screw which was factory set for a 1.8 and not a 1.5.
I can't tell you how happy this makes me to have found out how to instantly solve all of the problems with just one simple procedure.
It was really dicey breaking loose the idle adjustment screw without stripping it. I used a fractional inch hex key as it was slightly larger than the metric one, and applied Liquid wrench to the threads. Then I put in the hex key and tapped it with a mallot. It turned really hard right at first and then was much easier as the oil penetrated the threads. Now it twiddles without being loose. I'm going to set it with silicone so that if I ever need to readjust it, the silicone plug can be removed easily.
Dyno shop, here I come!
Old 01-10-2013, 02:41 PM   #988
Old 01-10-2013, 02:54 PM   #989
Bluevitz-rs
How much less room compared to the plastic manifold? Just asking because the Echo doesn't have a lot of space between it and the rad.
Old 01-10-2013, 03:07 PM   #990
tooter
play every day
tooter's Avatar
A lot less...
The overall depth of the plastic stock manifold is only 130mm, while the depth of the tooter is 210mm.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
