Old 01-08-2014, 11:59 PM   #1
echo-francis
Drives: toyota echo
fidanza flywheel
I just receve my fidanza flywheel an will install it soon.
does some body has some tips? what to do or not to do? when installing it
I have a 2005 toyota echo.
echo-francis is offline   Reply With Quote
Old 01-09-2014, 09:00 PM   #2
Viperoni
Drives: 2005 Toyota Echo
-Install a new clutch at the same time
-Get new flywheel and pressure plate bolts
-Definietely get a load leveler for your engine hoist
-You may need to unbolt the subframe a bit to give you enough clearance to slide the tranny out of the way
-You probably won't have to, but getting the axles out of the tranny is a huge pain
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 05-02-2014, 06:14 PM   #3
echo-francis
Drives: toyota echo
do you think a transmission jack can replace the engine hoist?
and is it really necessary to unbolt the subframe?
because where I will be to work on this I will have 1-2 friends and more then 1 transmission jack
Old 05-13-2014, 07:30 PM   #4
echo-francis
Drives: toyota echo
bump
Old 05-13-2014, 09:04 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
i pulled the power train to change my flywheel and clutch. makes the flywheel and clutch part easier.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 05-15-2014, 05:00 PM   #6
2005rs
Drives: 2005 Echo Rs
I put in a fidanza flywheel in my echo this winter.
Replace the clutch housing, clutch and throw-out bearing.
I pulled the drive shafts ; not that hard when you figure out where to pry from.
I had to lower the sub-frame; I tried, but couldn't find a way around that.
I used a cut up office chair and car jack as my transmission jack. Not ideal but it worked.
I used the front strut bar and garage rafters as an engine hoist. Again crude, but it worked.
2005rs is offline   Reply With Quote
clutch install & flywheel questions So Cal xb visitor Performance Modifications 3 11-04-2013 11:43 AM
Questions for new flywheel and clutch mrbond Performance Modifications 11 07-11-2013 08:17 AM
Flywheel question-1nz conversion-2003 Model Echo56 DIY / Maintenance / Service 0 05-21-2013 11:42 PM
Cp Pistons, Pauter rods , greddy, fidanza and other for 1NZ-FE!!! Giupo Items for Sale by private party 11 08-25-2009 03:57 PM
lightweight flywheel from fidanza dngz Performance Modifications 34 02-04-2009 12:02 AM
