Old 11-01-2009, 04:31 AM   #19
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
pity you are too far from me, I'd do it for $20
Old 11-01-2009, 04:59 AM   #20
window_lee
Drives: Yaris RS 2007
Originally Posted by fmicle View Post
Garm's stuff is already heavily discounted, trust me, you won't find a better price anywhere else on the Internet... Not on this planet anyways...
+1
just try to plz more parts at once and then ask for discount ahahhah
window_lee is offline   Reply With Quote
Old 11-01-2009, 11:04 AM   #21
If you can change a tire you can install this. OR you must have a friend that can help (two people makes it so much more fun).
If you want to call me on the phone, I will coach you, in person, through the whole thing.
Old 11-01-2009, 11:57 AM   #22
coffiend
coffiend's Avatar
Drives: 08 Black LB
^ what other parts dealer would do that?
None that I know of....
Old 11-01-2009, 12:02 PM   #23
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Originally Posted by IsLNdbOi View Post
Yeah, me installing it is not going to happen.
I've never worked under the car and don't know where I'd even attach it. I could go to my Toyota dealer and have them install it, but then that would bring the total cost way over what it's worth.
Everybody starts somewhere and this is a good place to start. It *really* is as easy as everyone says it is. Four bolts and you're done.
Old 11-01-2009, 01:18 PM   #24
detroiter
detroiter's Avatar
Garm really will help you through it over the phone. I know firsthand because he helped me get the 23mm UR bar on when I thought there is no way it would fit. Thanks again for that help!
Old 11-01-2009, 02:42 PM   #25
IsLNdbOi
IsLNdbOi's Avatar
I've never changed a tire before, but if you can coach me over the phone that might work.
Old 11-01-2009, 02:45 PM   #26
supmet
Drives: 2007 4 Door Yaris
I asked out of morbid curiosity at the dealer when I got mine, and they wanted 100 dollars for the install
Just find the DIYs on here, print them out, and call garm if you get stuck(which you really shouldn't)
Old 11-01-2009, 03:04 PM   #27
IsLNdbOi
IsLNdbOi's Avatar
I don't have any tools or gear to raise the car and someone said it would be dangerous and difficult to do w/o raising the car.
Old 11-01-2009, 03:31 PM   #28
CtrlAltDefeat
I ♥ Yaris
you will have to remove the nuts that hold the shocks on both sides... one side you can just slip on over the bolt... the other side you have to pull the bolt out in order to get that side into position, personally I'd be afraid to move the bolt out of the shock with the weight of the car pressing on it. Not to mention how hard it would be to move the bolt... I put my car on jack stands then jacked up the crossbar a tiny bit to loosen the pressure on that bolt, but beyond that, it's 4 bolts you have to deal with...
Old 11-01-2009, 03:38 PM   #29
IsLNdbOi
IsLNdbOi's Avatar
I was following just fine until you got to the words jack stand. Is that the thing under the driver seat? Won't "jacking" up the car on one small point like that put too much pressure and then warp that small point you jack the car up on?
Old 11-01-2009, 04:22 PM   #30
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
If the car is a daily driver, I'd worry more about the suspension setup of a 23mm than I would the price. Assuming the material is similar and that both bars are solid there's a much better chance of inducing snap oversteer withn the stiffer rear bar.
bearda is offline   Reply With Quote
Old 11-01-2009, 04:50 PM   #31
IsLNdbOi
IsLNdbOi's Avatar
So you recommend the 19mm one?
Old 11-01-2009, 05:54 PM   #32
CtrlAltDefeat
I ♥ Yaris
No the jack stands are these things. You can buy the cheap ones (which is all our cars need) for about $20 at walmart or other retail store. It's more of a safety thing. You jack up the car on one side and place the jack stand on the hard point just in front of the rear wheel at the highest setting you can get it on. then you lower it down onto the jack stand. You repeat for the other side. once the but of the car is in the air it should be cake to install the sway bar. You'll just need to place the jack under the shock that has the bolt you have to remove and jack it up a hair to remove the pressure. Here is my install with pictures...
Old 11-01-2009, 06:16 PM   #33
bearda
bearda's Avatar
I recommend knowing what problem you're trying to fix and what side effects it has before starting to throw parts on your car. That's it.
Old 11-01-2009, 06:43 PM   #34
RedRide
RedRide's Avatar
I got Garm's 23mm bar and I have absolulty no regrets.
My Yaris is a DD used in comunting to work in all kinds of weather and there is no downside to the 23mm.
Old 11-01-2009, 06:44 PM   #35
tomato
tomato's Avatar
OP, did you read this thread?
http://www.yarisworld.com/forums/showthread.php?t=14084
It might help you answer the 19" v. 23" question.
If you don't have any tools, maybe you could go to a meet and see if some of the members are willing to help you out?
Old 11-02-2009, 04:34 AM   #36
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Installing my 19 mm Ultra Racing sway bar was really easy. I didn't even try to jack up the car from under the shocks; you don't need to. Keep it simple. You only need to remove the nuts from the bolts in order to install the sway bar, so pressure on the bolt from the shock is no issue here...
fmicle is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 11:29 AM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 02:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
