FS: Push to Start Trim Piece
I bought a batch of these "Push To Start" trim pieces from Europe. These are used on European Liftbacks, which have the Push To Start feature. They fit perfectly with the JDM Vitz, Camry, Avalon, or Lexus PTS switch.
I bought enough to get a reasonable discount, so these are $30 shipped. Here are some pictures of the piece and of one in my 09 Liftback with a JDM Vitz PTS switch installed. PTS Trim.jpg PTS Trim 1.jpg PTS Trim 2.jpg |
wont fit a sedan huh?
I love momentum.
How hard is it to wire up the actual button?
I created a module that works with the OEM Engine Start/Stop Switch, and lets the switch start and stop the engine (and it drives the LEDs on the OEM switch).
There are 5 wires that connect between the switch and the module, 3 wires that connect to the ignition switch and one wire that gets tied to chassis ground. PTS - Prewired.jpg Here's a video of the switch in action, which also explains the installation: http://www.youtube.com/watch?v=v6zinlD58Eg |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
So how much would it be for the whole set up? (trim piece, push to start button, and the module)
C-Lift ![]() -------------------------------------------------------------- Current Mods: MI Armrest; Full LED conversion (interior and exterior); RS spoiler; Tinted windows; Tanabe DF210 lowering springs; aftermarket door speakers; 12" RF P3 subwoofer with custom box wrapped in Neffy; seat covers; HID 8000K headlights; HID 3000K foglights; 13mm PG hub spacers; muffler delete with dual tip; eyelids; and.. A little red Domo mascot!
#7 | |
Module: $55 shipped Switch: $35+ on eBay or ~$70 from your local dealer The switch connector and pins are expensive from the dealer and hard to find from junkyards, so it is most cost effective to solder to the pins. If you purchase a switch and ship it to me I will do the soldering to the module wires (with an inline connector to make installing it easier) for no extra charge. The picture above of the module and switch is an example of a direct wired switch - That one is alainmikli's TRD PTS switch, which I assembled for him last weekend. |
Great Scott!! This is a great deal for an OEM trim piece with shipping!!
If I had the extra funds laying around, I'd definitely do this!! Bump!!
DON'T LIKE ME? TAKE A SEAT WITH THE REST OF THE BITCHES WHO ARE WAITING FOR ME TO GIVE A FUCK. Sponsored by: Micro Image http://microimageonline.com |
![]() ![]() Drives: 4 door hatch Join Date: Oct 2008
Would you happen to know if your start button would work in a 06 Scion xA?
![]() ![]() Drives: Red Yaris Liftback Join Date: Mar 2009
Would your module work even if the yaris has a remote start installed?
Mr. 155 and climbing
Just as a heads up when you pull the right hand trim piece off from the center console there is a round hole which looks to be that size to accommodate the push to start mechanism. I was going to use that hole for another project however this has my mind moving in a different direction. All one with a sedan would have to do is punch out the correct size hole and then would be able to mount the PTS I would wager.
Any insight or ideas on this CTScott?
#14 | |
#15 |
やりすぎだ~
Can't view the video! Damn Rick Astley keeps showing up on youtube! Firefox glitch?
Looks nice. Wish I could see the video for it. |
#16 | |
Yup...that is it which means that if the part number could be found then there must be a replacement panel for the sedan overseas that already has the hole as a factory spec...I was going to use it to run my USB for my HU through, but might need to 86 that idea and find a new spot as I kind of like the idea of the PTS...
#17 |
![]() ![]() ![]() Drives: 07 4d yaris and 02 Trans Am Join Date: Jun 2009
mine is a full panel
is there a trim piece that I can use?
02 T/A AUTO Metalic Silver. 07 Yaris M5. ![]() Best ET is 11.13 @ 120 MPH with 1.47 60FT 11.13 sec vid BurnOut Vid |
#18 | |
![]() ![]() Drives: VIOS Join Date: Nov 2009
hi scott, will this module work with yaris sedan?..how much to shipped to Malaysia? |
| Push Button Start | Stoln | Europe (continental) | 20 | 05-24-2010 08:56 AM |
| push start vs electric start? | yaris2010RS | General Yaris / Vitz Discussion | 18 | 04-07-2010 03:20 PM |
| FS: Dashboard Covers for the '07-'09 LB, ProClip Mounts, 180mm Double Din Trim Piece | IsLNdbOi | Items for Sale by private party | 14 | 09-25-2009 01:21 AM |
| FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece | IsLNdbOi | Items for Sale by private party | 2 | 08-23-2009 03:37 AM |
| Canadian DD trim piece. Can any of you Canadian members get one? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 12-20-2008 01:52 AM |
