Old 12-03-2011, 06:03 PM   #55
SimTronik
Machinist
Drives: Yaris sedan 2010
It works! Can beleive i have a cruise control for 40 bucks :) Thanks sir.
SimTronik is offline   Reply With Quote
Old 12-05-2011, 05:43 PM   #56
jiroj.amaralikit
Drives: BMW 3 Series
I have the item if you are interested.
jiroj.amaralikit is offline   Reply With Quote
Old 12-09-2011, 01:00 PM   #57
33OH
Drives: '08 Yaris
Scott, can you PM me what all I'd need to run this on my 2008 Yaris LB 5 speed? Interested but not sure if the wiring would be over my head.
Old 12-09-2011, 01:05 PM   #58
You can definitely handle it. With my DIY many who have never touched any wires in a car have self installed it.
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 12-09-2011, 01:23 PM   #59
A-Dingo-Ate-My-Baby
Drives: yaris
protip
for the two screws, you can use 2 standard server rack mount screws
found in most computer rooms or racks....
they are typically the same size and thread pitch, and short enough as well
that is what I used on my cruise control after digging through my junk drawer
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-09-2011, 09:26 PM   #60
deathwisher
Drives: 2007 Yaris Sedan
Originally Posted by A-Dingo-Ate-My-Baby View Post
protip
That depends on if you are in Canada or US... >.> Canada's server rack uses #10-32 screws. I can't remember which one the US ones used...
deathwisher is offline   Reply With Quote
Old 12-14-2011, 12:22 AM   #61
GAAzureMach1
Converted Gearhead
GAAzureMach1's Avatar
Drives: 2010 Yaris HB 3 Door Base Red
Hey Scott, I have a 2010 HB 3dr L Automatic with the convenience package. Can you pm me with cost and payment info?
Thanks, Todd
Commuter -10 Toyota Yaris, HB, 3 Dr, Base, auto, Red
Track Queen -03 Ford Mach1, 1UP, 4.6 DOHC V-8, TR-3650 5 spd Man, Azure Blue, Highly Modded
Grocery Getter -02 Ford Excursion, Ltd, 6.8 SOHC V-10, 4R100 Slush Box, Forest Green, Few interior mods
Tow Pig - 94 Ford F350, XLT, 4 Dr, Crew Cab, 2wd, 7.3 idi diesel, E40OD Slush Box, Bright Red, Mildly Modded
GAAzureMach1 is offline   Reply With Quote
Old 12-15-2011, 02:20 AM   #62
YAR1S
YAR1S's Avatar
soooo are these plug and play for 2007 liftback? *crosses fingers*
-Jen <3
Old 12-15-2011, 06:54 AM   #63
Yes. There is a little bit of wiring that needs to be added for 06-08 Yaris, but it is just a matter of adding a couple of pins to two connectors and running the wire from the ECM to the steering column. Take a look at my DIY to see exactly what's involved:
Old 12-25-2011, 12:26 PM   #64
thestranger
Drives: 09 3-door LB/MT
hey Scott, I know I'm like a year late... got an '09 lb/mt. any more stalks for sale? :)
thestranger is offline   Reply With Quote
Old 12-25-2011, 09:05 PM   #65
Yes. I still have plenty.
Old 12-31-2011, 08:06 AM   #66
GAAzureMach1
Converted Gearhead
money sent.
Old 01-06-2012, 08:49 PM   #67
GAAzureMach1
Converted Gearhead
Smile
Scott I got it in the mail today. Took me 20 mins for the whole install. Easiest mod I have ever done. Thanks a bunch!
Old 01-22-2012, 01:06 PM   #68
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
if you have any left for sale, i would be interested
ttr125fan09 is offline   Reply With Quote
Old 01-22-2012, 01:37 PM   #69
I do still have some.
Old 10-25-2012, 03:09 PM   #70
Herder
Greenie
Drives: 2010 Yaris Liftback 3dr
CTScott, you still have any stalks? I have a 10' LB Auto no power package
Herder is offline   Reply With Quote
Old 10-25-2012, 03:17 PM   #71
I do indeed. I replied to your PM.
Old 10-25-2012, 10:20 PM   #72
alpha1
Drives: 2011 yaris 1.5 Auto-sedan
I just installed the cruise control ordered from CTScott for $40.00 stalk & shipping and it was simple, relatively quick (about 1 hour total), and works great.
Installed on car listed 2011 yaris auto sedan with power windows/doors/ & blinking light on dash for immobilizer etc.
After disconnecting the battery, I only had to 1. remove the two Torx screws with a T-30 2. lift the air bag to expose the area to put the new stalk in and push it through the 3. new hole I drilled with a 1 inch drill (did not have 1& 1/8). 4. I then screwed in the 2 new phillip screws supplied by CTScott. 5. I then disconnected the white plug from the stearing column and Connected the new white plug on the stalk. 6. I then disconnected the other end of the original wire that had the white plug and the other end was a clip on wire to the air bag area; and connected the new slip on wire here and I am done except for reconnecting the air bag with the torx screws. (I never had to nor did I disconnect the air bag & other yellow wires) (Both yellow wires stayed intact from the air bag to the stearing column the entire time). (only 1 wire was removed to install this)
To save someone else time..........A regular T-30 usually comes in a box with a simple straight screw driver type handle to turn the T-30. I was unable to turn this with my hand strength. I quickly picked up my 1/4 inch rachet set and a small extension and added a 6.5mm socket and slipped the T-30 into the 6.5mm socket. It now became simple to turn the T-30 screws on both sides of the column (Leverage is great). Also squeeze the top center of the white plug and center of the clip to remove that one wire that you are replacing.
It is really simple, there was just a lot of previous older models and many pages of diagrams listed that no longer were needed for new models etc. that did not have all the wires etc. coming to the stearing column that made it a little confusing. The newer cars will all probably be simple with the power windows etc. using the oem stalk from CTScott.
Thanks Again.....Works great.... Great buy for oem cruise control....dash board icon shows it's working....tap for increase speed works...etc. etc.
I just read the Birthday listing, so ......... Happy Birthday CTScott
alpha1 is offline   Reply With Quote
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
