Old 01-29-2013, 10:13 PM   #1
trx680
Drives: 2008 Yaris 4 door
grinding noise from engine area, bearing maybe??
08 yaris, 70k miles
about a month ago started getting a grinding noise coming from engine area. I cant pinpoint exactly where. Sounds like a bearing going bad.
Anyone have this problem?
thanks !!!
trx680 is offline   Reply With Quote
Old 01-29-2013, 10:54 PM   #2
yariseggvvti
Drives: Yaris Hatchieback
It could be the water pump bearing or alternator pulley. Do you hear it while you drive or only makes the noise in idle?
yariseggvvti is offline   Reply With Quote
Old 01-29-2013, 11:04 PM   #3
trx680
I can hear it at all times.
Its more noticeable when I'm sitting still with no road noise.
Old 01-29-2013, 11:12 PM   #4
Loosen the belt (by loosening the two alternator bolts) and try rotating the alternator and water pump by hand to see if either is obviously the culprit.
Old 01-29-2013, 11:21 PM   #5
brg88tx
Drives: 07 Yaris Sedan, Auto
i bet it's the water pump. mine grinded pretty bad when it went at about 75,000 miles. i bought an aftermarket pump for $40 and had local mechanic replace it for $130 labor....much cheaper than the $450-500 toyota quoted me. and i think the oem toyota water pump is crap anyway, so i wanted a different brand. mine was gmb brand.
brg88tx is offline   Reply With Quote
Old 01-30-2013, 12:12 AM   #6
Hershey
" and i think the oem toyota water pump is crap anyway, so i wanted a different brand. mine was gmb brand. "
Hopefully the new waterpump installed under warranty will last longer . 200,000 plus miles would be good .
Old 01-30-2013, 08:13 PM   #7
bairjo
Did you check the gonkultor connection? Sometimes if that slips, you will hear a grinding sound when the air is lost in the water collection chamber. If that is in fact the case, you will need to barrow a vacuum stretcher from Autozone. They will require a deposit of course.
Old 01-30-2013, 10:25 PM   #8
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Scott, did you get another Yaris? Looks good.
screenprintr is offline   Reply With Quote
Old 01-30-2013, 10:36 PM   #9
The red one is Crashy 2. I rescued her from a deer hit and put her back on the road. Here's her story:
http://www.yarisworld.com/forums/showthread.php?t=40321
Old 01-30-2013, 11:26 PM   #10
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
It's deff the water pump, mine made grinding noises when I was at a stand still. Eventually after me ignoring it for a while my belt completely ripped off without me noticing and my car started to overheat, had to replace the water pump did it myself. 80$ for the part, shop wanted to charge 400 -_-
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 01-31-2013, 12:22 AM   #11
bairjo
Without looking at how hard it would be access, you could use a long piece of wood rod or something like this as a stethoscope. Hold one end against the various components and the other to your ear. You can do this with the easy ones and eliminate those. Unless you have a real stethoscope. However, You probably could not do this with the water pump due to the location though....just watch out for the moving belt etc.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 03:39 PM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 01:34 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 11:45 PM
