Old 02-27-2013, 10:04 PM   #19
dragoonmc
Drives: 07 hatchback
It has to sound better than the coaxials on stock wiring lol
dragoonmc is offline   Reply With Quote
Old 02-28-2013, 07:14 AM   #20
sickpuppy1
Drives: 2010 Yaris Sedan
Mine only had to live a week with stock wiring, then it went to shielded 12 gauge and 60rms/channel
Old 02-28-2013, 12:34 PM   #21
UberSilver
UberSilver's Avatar
No need to spend a lot, these will play loud and clear, with good bass. I've got them in my HB front and rear.
You'll need to remove the stock plastic mount and add spacers.
http://www.onlinecarstereo.com/CarAu...TS-D1702R.aspx
Originally Posted by dragoonmc View Post
Looking for some advice on a good set of 6.5" component speakers for the front of my HB
I would like to spend less $160 unless you convince me that spending more will be worth the money in the sound.
I do know that an external Amp will be recommended and am open to suggestions for that as well to get the most out of my speakers.
The speakers will be going in when I do some sound deadening in the car so It should make for a huge difference hopefully.
Old 02-28-2013, 04:17 PM   #22
dragoonmc
Uber did you read the whole thread?
Cause I already ordered speakers and already had a set of speakers about like those and am no longer happy with them.
Old 02-28-2013, 08:43 PM   #23
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Are these speakers actually better than stock? Or good? They seem so inexpensive.
Colin Chapman disciple
Old 02-28-2013, 08:47 PM   #24
dragoonmc
I Imagine that they are simply a replacement if you destroy a stock speaker for some reason
Old 02-28-2013, 09:05 PM   #25
UberSilver
UberSilver's Avatar
No, just putting out my findings, that one can get good sound for cheap.
I've got $4k. in my land cruiser system(all off Ebay), and it sounds fantastic!
But my <$300. Yaris system sounds 75% as good.
Glad you got it sorted out.
Old 02-28-2013, 09:14 PM   #26
UberSilver
UberSilver's Avatar
Good choice going with neo magnets, your windows will thank you.
Also, If you look at the back speaker holes, there's is room for a shallow mount 8" woofer on each side. You'll need to do a little fab work, but I measure it out, and it will fit.
I like Earthquake SWS, but there's a ton of shallows out there.
I decided to be a little more spendy and ordered these
http://www.sonicelectronix.com/item_...io-MM6501.html
and a used Polk PA660.4
http://www.polkaudio.com/products/pa660_4
Old 02-28-2013, 09:44 PM   #27
why?
why?'s Avatar
Drives: Yaris LB
And if you put that 4k system into your Yaris, you'd be needing ear replacement surgery really quick.
Just looking at some sub packages, 4000 watts. I couldn't imagine surviving that much power in a Yaris.
Old 02-28-2013, 10:08 PM   #28
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Crunch, Autotek, Hifonics and Mb Quart are all the same company. I've used there stuff and would use it again without hesitation. But not everything they put out is great. I do research and go from there.
The Powerbass i posted will sound pretty damn good.
Others may say it's cheap bs. Set properly they'll do the job and not break the bank doing it.
Cadence is another good budget brand.
So is Crescendo. Look around on some of the audio forums and you'll see these brands.
Old 03-01-2013, 12:47 PM   #29
UberSilver
UberSilver's Avatar
My land cruiser system is only 900 watts RMS. and only consist of 8 speakers.
It's a SQ system, not an SPL.
Old 03-01-2013, 08:39 PM   #30
why?
why?'s Avatar
Drives: Yaris LB
still that Land Cruiser is a behemoth. That is enough power to fill the area?
Old 03-01-2013, 10:55 PM   #31
Yarflana
Drives: 2008 Base Model
tag
Yarflana is offline   Reply With Quote
Old 03-09-2013, 08:19 PM   #32
dragoonmc
Got it all installed and besides some hum that I think is because I am using speaker level inputs it sounds great
Old 03-09-2013, 08:27 PM   #33
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Are you anywhere near Henning, IL?
― Thomas Paine
Old 03-10-2013, 10:50 AM   #34
dragoonmc
sq
I'm a few hours from there and go that direction probably once a month
Old 03-10-2013, 11:21 AM   #35
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I was going to say, if you ever want to troubleshoot with someone who knows something about sound, the current Sbring Break Nationals SQ champ in the Pro class lives in Henning. He also used to drive (and compete) with a Yaris.
If you want, I can get you two together.
― Thomas Paine
Old 03-10-2013, 09:54 PM   #36
dragoonmc
that would be cool. might actually get to hear a good system
2012 Audio Upgrade FAQ and Build Log muffin_top In Car Entertainment + Electronics (audio / video / alarm) 19 01-19-2022 06:28 PM
Mtx-THdome-axials Front speaker upgrade Yaris_That DIY / Maintenance / Service 3 02-20-2011 12:02 PM
Yaris T1 stock speaker upgrade CrzyCrg In Car Entertainment + Electronics (audio / video / alarm) 7 06-20-2010 06:02 AM
HIFONICS ZXi6.5C ZEUS 6.5" 500W Component Car Speaker _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 20 03-13-2010 11:19 AM
Need help with Speaker upgrade Arkhangel DIY / Maintenance / Service 6 11-28-2006 10:52 PM
