#1 |
![]() ![]() Drives: 07 hatchback Join Date: May 2012
component speaker upgrade
Looking for some advice on a good set of 6.5" component speakers for the front of my HB
I would like to spend less $160 unless you convince me that spending more will be worth the money in the sound. I do know that an external Amp will be recommended and am open to suggestions for that as well to get the most out of my speakers. The speakers will be going in when I do some sound deadening in the car so It should make for a huge difference hopefully. |
You can get a couple of good coaxial speakers and an amp for $160
Why would you like component speakers if you are just adding an amp? D.
. CLA 250, 4MATIC |
#3 |
Roadrunner Jr.
Drag...
To add to what D is saying, what is around your area in the way of brands and shops?
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#4 |
What problem, there is no problem, he just needs an upgrade with a budget.
Better if he can get it with an amp within the budget. look at it this way... it will sound better 2 new speakers + amp than 2 new components with no amp. D.
. CLA 250, 4MATIC |
#5 |
Roadrunner Jr.
ahhh...the rule of absolutes.
Lord it stinks in here.
#6 |
Upgrade your headunit first.
If you don't have experience with setting up speakers and amps don't spend 200 dollars on speakers. Chances are this is going to be a learning experience and with an amp connected to 6.5's you'll have them bar b que'd in a month. Then you'll be left with a 200 dollar set of paper weights. If you are starting out. (Disregard if you're a pro ) Headunit first ( there goes your $160 budget ) 2 channel amp for only the front speakers 4 channel to replace all 4 speakers. 50 watts RMS should be enough. $100. You can find an okay beginner set of speakers for $60 or less Amp kit $30 If you want to run speakers off your headunit you will be pushing a whopping 20 watts of more than likely fully clipped power to you speakers which can handle about 50 watts RMS at which point you'll more than likely blow the speakers and we'll get into a heated discussion that underpowering speakers overheats them and melts the coils . So highly recommend. Get an amp.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#7 |
Options.
http://www.sonicelectronix.com/viewc...rder=price_asc http://www.sonicelectronix.com/item_...t-REF4.50.html http://www.amazon.com/KnuKonceptz-KC...1989514&sr=1-1 If you run all 4 channels you'll need another set of RCA's . . .
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 Last edited by _S7V7N_; 02-27-2013 at 01:39 PM. |
#8 |
Oops I forgot to say that I have a Kenwood DNX7140 and currently have some 3 way cheaper speakers that were probably $70 a few years ago in the front locations. Hence why I am looking at getting components because I am not happy with the imaging of the stock locations nor am I happy with the tinny sound of these speakers.
I might eventually get an 8" sub to put in a sealed box somewhere in the car. As for what is around me I have no idea as I am in central Illinois and have never heard of any audio places around here. |
#9 |
Roadrunner Jr.
Are you near Henning?
#10 |
I will be this weekend. Is there a good shop there?
#11 |
http://www.amazon.com/Polk-Audio-DB6...k+Audio+db6501
These seem like a good bang for the buck |
#12 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
For what it's worth, my pair of Pioneer 2-way 6.5" has lasted 6+ months on the stock head unit. I don't normally turn it up past 35, depending on the level of the recording, but it's also rarely below 25. I'm much happier with them than the stock set.
#13 |
#14 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
I'll second the Polk Audio DB6501 speakers. Thats what I have in my car and like them alot! Do yourself a favor though and get some speaker wedges too to aim them up a bit...like toward the shifter. Makes a very noticeable difference.
I also would mount the tweeter in the windshield post. For ease of install, I put mine in the tranglular mirror section above the door (sedan) and the tweeter is a little overwhelming unless you turn the crossover down 3db. You get better imaging in the posts too. once i get new mirror covers I am going to move mine to the post also. |
#15 |
I decided to be a little more spendy and ordered these
http://www.sonicelectronix.com/item_...io-MM6501.html and a used Polk PA660.4 http://www.polkaudio.com/products/pa660_4 |
#16 |
Looks good. Let us know how it sounds.
#17 |
It has to sound better than the coaxials on stock wiring lol
#18 |
Mine only had to live a week with stock wiring, then it went to shielded 12 gauge and 60rms/channel
| 2012 Audio Upgrade FAQ and Build Log | muffin_top | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 01-19-2022 06:28 PM |
| Mtx-THdome-axials Front speaker upgrade | Yaris_That | DIY / Maintenance / Service | 3 | 02-20-2011 12:02 PM |
| Yaris T1 stock speaker upgrade | CrzyCrg | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 06-20-2010 06:02 AM |
| HIFONICS ZXi6.5C ZEUS 6.5" 500W Component Car Speaker | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 03-13-2010 11:19 AM |
| Need help with Speaker upgrade | Arkhangel | DIY / Maintenance / Service | 6 | 11-28-2006 10:52 PM |
