#19 |
![]() ![]() Drives: 07 hatchback Join Date: May 2012
It has to sound better than the coaxials on stock wiring lol
#20 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
Mine only had to live a week with stock wiring, then it went to shielded 12 gauge and 60rms/channel
#21 | |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
No need to spend a lot, these will play loud and clear, with good bass. I've got them in my HB front and rear.
You'll need to remove the stock plastic mount and add spacers. http://www.onlinecarstereo.com/CarAu...TS-D1702R.aspx Quote:
#22 |
Uber did you read the whole thread?
Cause I already ordered speakers and already had a set of speakers about like those and am no longer happy with them. |
#23 | |
Only Happy When it Rains
Colin Chapman disciple |
#24 |
I Imagine that they are simply a replacement if you destroy a stock speaker for some reason
#25 | |
I've got $4k. in my land cruiser system(all off Ebay), and it sounds fantastic! But my <$300. Yaris system sounds 75% as good. Glad you got it sorted out.
#26 | |
Good choice going with neo magnets, your windows will thank you.
Also, If you look at the back speaker holes, there's is room for a shallow mount 8" woofer on each side. You'll need to do a little fab work, but I measure it out, and it will fit. I like Earthquake SWS, but there's a ton of shallows out there. Quote:
#27 | |
Just looking at some sub packages, 4000 watts. I couldn't imagine surviving that much power in a Yaris.
#28 |
Crunch, Autotek, Hifonics and Mb Quart are all the same company. I've used there stuff and would use it again without hesitation. But not everything they put out is great. I do research and go from there.
The Powerbass i posted will sound pretty damn good. Others may say it's cheap bs. Set properly they'll do the job and not break the bank doing it. Cadence is another good budget brand. So is Crescendo. Look around on some of the audio forums and you'll see these brands.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#29 | |
It's a SQ system, not an SPL. |
#30 |
still that Land Cruiser is a behemoth. That is enough power to fill the area?
#31 |
tag
#32 |
Got it all installed and besides some hum that I think is because I am using speaker level inputs it sounds great
#33 |
Roadrunner Jr.
Are you anywhere near Henning, IL?
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#34 |
sq
I'm a few hours from there and go that direction probably once a month |
#35 |
Roadrunner Jr.
I was going to say, if you ever want to troubleshoot with someone who knows something about sound, the current Sbring Break Nationals SQ champ in the Pro class lives in Henning. He also used to drive (and compete) with a Yaris.
If you want, I can get you two together.
#36 |
that would be cool. might actually get to hear a good system
| 2012 Audio Upgrade FAQ and Build Log | muffin_top | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 01-19-2022 06:28 PM |
| Mtx-THdome-axials Front speaker upgrade | Yaris_That | DIY / Maintenance / Service | 3 | 02-20-2011 12:02 PM |
| Yaris T1 stock speaker upgrade | CrzyCrg | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 06-20-2010 06:02 AM |
| HIFONICS ZXi6.5C ZEUS 6.5" 500W Component Car Speaker | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 03-13-2010 11:19 AM |
| Need help with Speaker upgrade | Arkhangel | DIY / Maintenance / Service | 6 | 11-28-2006 10:52 PM |
