#37 |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
I did, it's completely backed out
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
#38 |
You must have a vacuum leak somewhere then.
Sent from my iPod Touch |
#39 | |
Something I noticed is that my rev limit increased. It's topping out at 6700 rpm now, Not sure how that happened. Regarding the cable being too short, I think this will have to be my solution;
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin Last edited by Ryze268; 10-29-2014 at 05:51 PM. |
#40 |
Did you port match the intake manifold.
#41 | |
I made a new gasket and it still wouldn't idle below 1500 rpm, I grew frustrated and put back on the stock TB. I'm going to leave it to continue my turbo build. I'll revisit this swap when I figure out where the leak is coming from.
#42 |
It could be the idle air speed controller.
I know the bypass port look very different between the two throttle bodies. Sent from my iPod Touch |
#43 |
If they can be swapped between the two, maybe that's the problem.
#44 |
Is that the sensor which is on the side with the coolant lines?
| wtb stock throttle body , cheap | blacksandiegovitz | Willing to Buy by private party | 0 | 09-21-2012 10:32 PM |
| THROTTLE BODY SWAP NO CEL!!!! | kou | Performance Modifications | 53 | 02-01-2011 04:01 PM |
| FS- 1ZZ Throttle Body, Spacer, NST SSK | MGargano | Items for Sale by private party | 9 | 09-01-2010 08:48 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
