Old 03-03-2016, 04:35 PM   #1
tmontague
tmontague's Avatar
Front sway bar oem diameter
anyone know of the diameter of the oem front sway/stabilizer bar on the Yaris sedan? I'm trying to buy some PU bushings and I found these ones http://www.ebay.com/itm/161865994138...%3AMEBIDX%3AIT
but I want to make sure that they fit first before I pull the trigger. Any thoughts?
Old 03-03-2016, 04:46 PM   #2
Jason@SportsCar
Should be a 23 (23.2mm if memory serves). Hatches got a 24, while the newer cars (like our 2015) has a 24 that is tubular instead of solid like previous years. I was using the smaller sedan bar until the even softer rate tubular bar came along.
Old 03-03-2016, 04:55 PM   #3
tmontague
tmontague's Avatar
thanks Jason, do you think the link I posted would work since the bushing is strapped down with the clamp to the bar? It is listed as compatible with the sedan and I can't imagine that 0.8mm would be a big difference.
Old 03-03-2016, 04:58 PM   #4
Jason@SportsCar
What makes you think you need them? Ton of work replacing those for pretty much zero benefit. If you just want bling put them on there and dont worry about if they fit right.
Old 03-03-2016, 05:01 PM   #5
tmontague
tmontague's Avatar
it's a cheap thing that I can do now to keep me busy and that will match nicely to PU control arm bushings down the road when my oem's go out. I have a handful of tools that will allow me to do this with the subframe still on the car. There's a nice video outlining this without dropping the subframe from someone in the UK.
I've been dying to do some work on my car and due to wedding expenses and school this is all I can really afford to do right now until the summer
Old 03-03-2016, 05:06 PM   #6
Jason@SportsCar
Spending money on a useless part just puts you further away from meaningful items.
Old 03-03-2016, 05:15 PM   #7
tmontague
tmontague's Avatar
very true...buuuuuut it's $20...and i'm dying to get under the car again. You definitely are correct though it won't do a whole lot handling wise.
Do you think it'd be ok for one to use that PU bushing on a 23.3mm bar?
Old 03-03-2016, 06:19 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I 2nd Jason, its one of the few jobs I absolutely hate doing. Don't waste your time replaceing the bushings, basically you'll need to drop the whole front suspension for something that no one will ever be able to see.
2014 BSpec Divisional Champion
Old 03-03-2016, 06:27 PM   #9
tmontague
tmontague's Avatar
already purchased a sandwhich plate adapter from Garm instead, ended up being the same price as what the bushings would've been and it's needed for my gauges this spring.
I'm confident I could have done the job without dropping the suspension with the right tools. It'd be a pita but should still be able to do it.
This spring I'll likely get under there and try and remove the bushing mount bolts so that I can apply some anti seize to them. I'll let you know if I was able to do it w/ out dropping the sub frame. My Echo's are corroded so bad I couldn't replace them if I wanted to.
Old 03-03-2016, 07:08 PM   #10
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Do you think the iQ would work on a yaris? Or vice versus since they share a lot of the same underside?
P.S. Thanks for the camber info again on the iQ, Jason. I had to change my sign in cause I couldn't post using my MugenReplica account.
MugenRep is offline   Reply With Quote
Old 03-03-2016, 07:53 PM   #11
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
2014 and 2015 Yaris front tubular sway bars the same it seems?
Both have part#488110D150 and seem easily accessible for under $100 online and MSRP is $105.76.
Old 03-05-2016, 06:28 PM   #12
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
If the iQ fits the Yaris as well, I stopped and picked up a digital caliper and the iQ front sway is 21.31mm according to it and solid design as far as I could tell reaching underneath quickly.
FS: Megan Street Coilovers and Whiteline Sway Bar. So-Cal! braytonia Items for Sale by private party 30 06-10-2013 12:25 AM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 10:47 PM
sway bar links contd jstantherprsn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-26-2011 03:58 PM
Front Sway Bar bronzebullet232 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-24-2010 06:50 PM
Sway Bar! dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 55 01-12-2007 04:31 AM
