Old 03-03-2017, 07:18 PM   #1
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Rear disc brake conversion?
I know the SE models comes with disc brakes in the rear, and the rest have drums.
Is there a kit to convert to disc? My drums are getting excessively noisy, and I bet discs are much quieter.
Thoughts and advice? Thanks!
m.flores.0928 is offline   Reply With Quote
Old 03-03-2017, 10:33 PM   #2
Alain93
Drives: Yaris 12
Google says Yes, in South East Asia.
Alain93 is offline   Reply With Quote
Old 03-04-2017, 03:29 PM   #3
Lair
Drives: 2016 5 dr Yaris LE
I'd like to add rear discs also.
Lair is offline   Reply With Quote
Old 03-04-2017, 03:31 PM   #4
m.flores.0928
Drives: 2014 Yaris
I honestly was thinking about just buying SE parts from a dealer and just making it work.
Old 03-06-2017, 11:02 PM   #5
Lair
LMK if you get a complete kit together - and how much.
Old 03-06-2017, 11:09 PM   #6
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
what mine look like
Old 03-06-2017, 11:14 PM   #7
m.flores.0928
Drives: 2014 Yaris
Originally Posted by justanotherdrunk View Post
what mine look like
Nice, thanks. That's the SE model, they come factory. I'm trying to figure out if I can get SE parts on my LE rear axle beam
Old 03-06-2017, 11:14 PM   #8
m.flores.0928
Drives: 2014 Yaris
If you can show pics of behind the hub, that would be fantastic!
Old 03-06-2017, 11:21 PM   #9
Dabuu
Radical Dreamer
Drives: spiritedly.
You're going to need the SE's rear torsion beam because the caliper mounting points are part of the beam.
Enjoy Family Car Sports
Dabuu is offline   Reply With Quote
Old 03-06-2017, 11:26 PM   #10
m.flores.0928
Drives: 2014 Yaris
That's what I was trying to figure out, thanks! Hmmm. I saw a kit a few years ago by MicroImage. Whatever happened to them?
Old 03-07-2017, 05:09 PM   #11
Jerkratt
Jerkratt's Avatar
and the rear beam axle wont bolt up to an older Yaris say MK2 mount points are different if you can get your hands on a set of caliper carriers you are set with the 2012 SE parts
edit: the e-brake lines are different length as well
"It hurts more when its wet"
Old 03-07-2017, 05:25 PM   #12
m.flores.0928
Drives: 2014 Yaris
Jerkratt, Im unable to see that image you shared.
So are you saying that a 2012 (or 2014, like mine) SE axle beam wont fit on the same year LE axle beam?
Moreover, this picture you shared you said is a conversion, so how/where can I get it?
Old 03-07-2017, 06:01 PM   #13
B.B._07
Drives: 07 5dr
The only way to make this work would be to get the rear torsion beam, caliper, and e brake cables from a wrecked mk 3 SE Yaris. Since there are very few wrecked mk 3 SE trim Yaris around your odds of finding one may not be so good. Buying these parts new is not really an option since it would be very expensive for the marginal performance boost. Since the Yaris is a very light car and 80% of the braking force comes from the front brakes I feel that rear disc's on the Yaris are more of an aesthetic upgrade. Also rear drums often require no maintenance and can typically last 120K before needing replacement.
Old 03-07-2017, 06:09 PM   #14
m.flores.0928
Drives: 2014 Yaris
You're entirely not wrong. My desire is honestly pure aesthetic. The squeaking is because it's cold outside it's not THAT big a deal.
Yea I was just wondering if there's a reasonable kit out there, I guess not.
Thanks!
Old 03-08-2017, 06:21 PM   #15
Jerkratt
Jerkratt's Avatar
Something is different with the mounting points to the car with the beam axle of the 2012 vs lets say the 2008. I have the Runstop rear disc conversion so I possibly can just use those carriers and get the 2012 rear caliper/rotor/pads. The E-Brake lines are also different lengths.
Old 03-08-2017, 06:27 PM   #16
Jerkratt
Jerkratt's Avatar
I work at a junkyard I'm just waiting for a 2012 SE to pop up.
Old 04-20-2018, 11:08 AM   #17
Pinchlite
Drives: 2007 yaris HB
No maintenance??
Constant ebrake adjustment.
Old 04-24-2018, 06:23 PM   #18
DarkShadowFox
what a pita. just buy the whole rear SE assembly from camelback.
disc, disc conversion, drum
Possible DIY rear disc conversion brushforhire Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 01-22-2024 03:36 PM
Need rear brake help! Star wheel/spring combo won't reattach msapocalypse DIY / Maintenance / Service 0 10-08-2016 06:19 PM
Yaris Rear Driving Lights Problem ap222 DIY / Maintenance / Service 3 05-31-2013 05:49 PM
drum brake conversion to disc brake bogartvitz Performance Modifications 8 04-15-2013 10:21 PM
