Old 06-12-2007, 04:24 PM   #1
redduck
Drives: Yaris
Noob questions.
I’m new here and I don’t even own a Yaris yet. But I am in the process of finding one I am happy with. Until I do I am trying to learn everything I can about the Yaris. So if you guys could help me get some things straight that would be much appreciated. So I am going to write out what I think I know and if I am wrong please correct me. No doubt you wouldn’t have any ways.
It has a 1.3 2NZ-FE engine that has about 84HP/6000rpm. It shares the same engine with a scion Xa and Xb. So does this mean most engine parts for the scion will bolt right up with the Yaris? It also shares the same suspension, correct? Again this means I can use parts from a scion?
ZPI seems to be the one leading with the most performance parts. Are there any other options out there? That is probably to broad of a question. What other companies make Yaris specific performance parts?
thanks in advance.
redduck is offline   Reply With Quote
Old 06-12-2007, 04:40 PM   #2
joey1320
joey1320's Avatar
Drives: Yaris LB
hello and welcome to the Yaris world. hopefully you find one soon and start enjyoing the benefits of the car.
fisrt of all the engine is a 1.5L dohc engine-coded 1NZ-FE.
and yes it is the same as the XA and XB. You can find more info on the
DIY section under the Service Manual.
the engine parts are speicfic to the models so so some may work but other may not.
ZPI is one of the vendors on this website that is here to help you. NST is another with a good following.
good luck.
joey1320 is offline   Reply With Quote
Old 06-12-2007, 04:45 PM   #3
kurokoma-kun
Drives: 2007 Yaris HB
Also, I think the engine makes 106 hp
my yaris, kurokoma-kun
Old 06-12-2007, 07:13 PM   #4
pathetiq
pathetiq's Avatar
Drives: yaris sedan aero
ya near the 4000rpm
pathetiq is offline   Reply With Quote
Old 06-12-2007, 07:26 PM   #5
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Thats 106 bhp. It has about 90ish whp. :)
Here you be...
http://www.yarisworld.com/forums/showthread.php?t=6338
Old 06-12-2007, 07:56 PM   #6
kurokoma-kun
If you are comparing models before buying though, you are most likely going to see all hp numbers expressed as whp, or at least that's what I was looking at before I bought.
Old 06-12-2007, 07:58 PM   #7
staticorex
staticorex's Avatar
hp at the dealership is in bhp.
Old 06-12-2007, 08:10 PM   #8
kurokoma-kun
I'm sure you are right, I guess we must have getting info from different sources. For example, one place I looked was Toyota website, and 106hp is what they show under specs; actually, everything I looked at online had the same figures. Since this is the info I used to compare cars I just thought redduck might find it useful.
Old 06-13-2007, 09:13 AM   #9
redduck
Drives: Yaris
very useful thank you
Old 06-13-2007, 12:52 PM   #10
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
One other thing to consider is buying a higher end model that has the side airbags, for your own safety. Mine is the base model, the only one I could affords. Also, don't let the dealer tell you it has a cabin filter: it doesn't, but no worries, the part #'s are all over this site. Good luck!
YarisTom73 is offline   Reply With Quote
Old 06-13-2007, 01:14 PM   #11
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Almost exclusivly, hp is expressed as flywheel horsepower. Thats what manufacturers report, thats what magazines use.
Auto Dynos however report wheel horsepower (whp, or fwhp or rwhp for front or rear wheel hp). A very expensive engine dyno will tell flywheel hp - and you have to test the engine out of the car for obvious reasons. The reason manufacturers give flywheel hp is because they test the output of the engine in R&D and engineering, not after the car is assembled.
WRBlue is offline   Reply With Quote
Old 06-14-2007, 06:13 AM   #12
Edd
Drives: None
In Australia, there is a 1.3L (YR), 1.5L (YRS or YRX), you are both correct in terms of specs for the engines, but I can't be sure of availability in different nations.
By the way, why do you Americans use Litres for engines? While you stick with the imperial system, shouldn't you call the 1.5 litre Yaris a 0.396 gallon Yaris?
Edd is offline   Reply With Quote
Old 06-14-2007, 10:38 AM   #13
staticorex
staticorex's Avatar
^ HA. I will. What do you have? A .396.
Old 06-14-2007, 09:15 PM   #14
WRBlue
CID - Cubic Inch Displacement. Yaris has a 93 CID engine . That went out with the first attempt to kill the imperial system in the 70s 4th gen F-Bodies had 5.7L not a 350 anymore :D . Chevy held out till the 80s - 3rd gen F-Bodies and 2nd gen Monte Carlos came with a 305
Old 06-18-2007, 08:37 AM   #15
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Here you be...
Exactly!
So many questions... ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 15 12-16-2008 07:52 AM
Performance Noob Questions fatjerkgary Performance Modifications 20 05-11-2007 11:20 AM
Few questions mystikdynasty03 Cosmetic Modifications (Exterior/Interior) 3 05-01-2007 08:42 PM
Newbie Questions jenna Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 03-27-2007 02:04 AM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 02:42 PM
