![]() ![]() Drives: 08 sedan auto Join Date: Nov 2008
uhoh....valve tapping already????
just bought the car
and i swear it's already valve tapping already..... and that's after the engine being warm time to head to the toyota dealer? |
loud injectors
its normal on newer toyota engines....they make a slight ticking
my xrs did it....yaris does it.....its nothing to sweat about
¦µ¶Œ€♦åËÆ⌐š└╘○Å╝◙þ·▲
I felt the same way. My brother said its the injectors, it seems the louder it is the colder it is outside :P
![]() Coming 2010: Toyota iSt CK edition (CooperKiller) stay tuned
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Car has mechanical tappet with a clearance so you will ALWAYS have valve noise. Car also has loud injetors - my wifes camry 2azfe was brought in for valve adjustment and it was just noisy injector. Let valvetrain wear in, its ALWAYS better noisy than tight. Just a note: cars will tend to stick valves during break in and you will get some noise until it clears. Please Leave the break in oil in for at least 2500mi - this oil has extra wear agents that your replacement oil will not have. It is great oil and should NOT be changed soon by worry wort. We have a inexpensive solid tappet cam and it need proper wear in. Your special break in filter will trap most all nasty wear items. Break -in runs about 15K miles if you look at UOA then wear tapers off to nothing. Dont worry this is not Kia or Mazda engine - it is quality motor with low oil consumption.
how many miles on it? Did you change oil yet? Dont beat it for 800 miles.
#8 | |
however, i bought it with 5000 miles. i've driven only 100+ miles with it since |
Wow, there are like 3-4 threads on this. Please search and you will find that it is perfectly normal for this (and many other) Toyota engines.
in my opinion the plastic intake manifold is the main reason for hearing the noises of the otto cycle at work, if it was a solid cast piece it would be a much quieter engine.
#13 | |
- the bro |
#14 | |
That car has cost you a fortune so far!
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
| WTB: Oil Control Valve/VVT Valve | bdc87 | Willing to Buy by private party | 4 | 05-22-2009 08:15 PM |
| excessive valve and or engine noise? | thomasward00 | General Yaris / Vitz Discussion | 3 | 06-07-2007 12:34 PM |
| 2007 Yaris LB - Valve Adjustments | Pavel Olavich | DIY / Maintenance / Service | 3 | 03-30-2007 05:34 PM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-25-2007 11:10 PM |
