#91 |
Learn to Relax
Job well done! Your car definitely whines. The S10 might hear it and back off. |
#92 | ||
I used to have 1700 posts
my yaris ate the first belt without spacer B because the alternator was out of alignment without it. i put the spacer on and the alternator sits straight up the way it should and will most likely not eat anymore belts since the spacer is on |
#93 |
lets clear something up.
MYTH: water methanol injection increases horsepower FACT: water/methanol injection lowers inlet temperature allowing higher boost levels without the risk of detonation/knocking. one problem. u cant re tune this kit to run higher boost |
#94 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#95 |
Broke Tuner
nice nice good job peterpoop! Enjoy the blitz!
EVERYTHING YOU KNOW IS WRONG |
#96 | |
Yah, i forgot to update that. We ended up using the spacer B. It is aligned perfectly with it. But yah, our kits might all be different. I didn't have to file down the manifold to make it fit. I also was running the belt that came with the kit today and yesterday, but squeeking occurred today and i bought the correct belt. Going to install the NGK iridium spark plugs soon, then take some videos tonight!
#97 | |
Ah I seeee. I probably wouldn't have gone that route, but that is nice to know. I am just saving up for my new exhaust setup and I'll be a happy man. |
#98 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
unless u get a diff pulley... which icorrect me if im wrong NST makes or is making or will make :D
"It hurts more when its wet" |
#99 |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Nice Bro ! So was it worth the money/time???
Garm is permanently high because he is the king of smokin' deals! |
#100 | |
That leaves a slight overdrive crank pulley as a possibility, but again, possible tuning issues.
#101 |
You know, I'd like a little more power. But who wouldn't, right? One could never be satisfied. But after knowing the power I've gotten with the blitz, I could never go back. So yes, worth the money/time. I just can't imagine how Garm's car would feel.
#102 |
Would the s/c guys go for an overdrive pulley? Is there room? Someone measure for that.
#103 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
How much enlargement is needed to see the benefit? I've seen overdrive pullies for the Mini that are just +2%... There's less than a finger's width of clearance between crank and w/p pullies on the yaris--don't think that's enough? I use my stock crank pulley as a paperweight however, I'll measure it tonight
#104 |
That is probably too close to do anything good with, unless a smaller w/p pulley was included.
OR, you could remove the w/p pulley and go with an electric water pump, but then you have a project on your hands...
#105 |
^ hint hint lol
#106 | |
Anything to be just like you Garm... as in finally rid of that stock ECM! It's full of sorcery
#107 |
Yes -- I have snuck up on my car at night a few times and witnessed the eerie green glow from the ECU.... wonder what (or who) it is communicating with?
#108 | |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
Garm and I have chatted about this a couple times. And where there is a will, there is always a way. We have worked around such limitations in other SC Toyotas in the past. Think late 80s Toyota MR2 SC. The dilemma we have has been the same one we have had since day one. We need someone with a SC Yaris, with the ability and willingness to test a pulley for us, and get some extensive dyno data with the stock pulley and any test pulley we offer. We have not had any serious takers. You all know my phone number, my screen name, and my Email address. I am ready to chat whenever you guys are. |
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| BLITZ supercharger kits IN STOCK | cali yaris | Micro Image | 34 | 06-02-2012 10:31 AM |
| anyone with Blitz supercharger? | yrsdrgn | Performance Modifications | 52 | 08-24-2010 07:57 AM |
| Blitz Supercharger vendors | sdyaris | Forced Induction Forum | 32 | 09-18-2009 12:28 AM |
| blitz supercharger!!! | djgab101 | Australia | 4 | 11-20-2008 05:06 AM |
