Old 04-06-2009, 02:05 AM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Hi CTScott. Where is this D2 connector located? Yes, I have aftermarket fogs without stalk switch.
1NZYaris: Do I just need to add power to PIN3 and then the indicator will light up?
Old 04-06-2009, 02:48 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
no you do not need to add power to pin 3 it is already there.
Old 04-06-2009, 08:22 AM   #3
If you pop the combination meter assembly off, it has two connectors D1 and D2. D1 is a 24 pin connector and D2 (the one you want) is a 16 pin connector.
By the way, I believe that Pin 3 on the stalk connector only works if you are using a fog light switch equipped stalk.
Old 04-06-2009, 11:37 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Not true at all , this is the way mine are wired, and they work great
Old 04-07-2009, 06:56 AM   #5
You installed the relay in the D46 position for that to work. The question is if his kit has the relay that installs there or if it has the external relay.
So, you are definitely correct that the stalk is not required, but the relay in that position, or the external relay wired through that position would be required.
The kit that I bought included an external relay, so I wired the indicator directly to the combination meter.
Here is the EWD for the fogs, which shows pin 3 and 4 on the upper left. The Fog light relay (at D46) is at the upper right. Its output feeds the fog lights and the combination meter indicator (center).
Old 04-07-2009, 06:01 PM   #6
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
the diagrames above is for useing the switch supplied with the kit .
if you want to use the factory combo switch all you need is the relay
(factory , or aftermarket) to plug into factory position as per diagrames.
Old 04-10-2009, 10:06 AM   #7
mrbond
mrbond's Avatar
So, let's see if I understand this. If I wanted to use the factory stalk instead of the little button that goes into the console, then all I need to do is wire up the fog lights, put the wire into the fuse box in the engine bay, and then put the relay where it's supposed to go? So I wouldn't even need that extra wiring harness for the cabin? If so, that's fantastic.
- A Toyota Yaris
- A whut Yaris?
Old 04-10-2009, 08:01 PM   #8
Meteorite_Marty
exactly the Yaris is already prewired, the only harness you need is the one to connect the Fogs together and to the fuse box in the engine bay.
Purchase the foglight stalk. The install is SOOOOOO much simpler and no messing with firewall and interior wiring. Plus, the fog light stalk is how it would come if you ordered your car with fogs from Toyota factory directly.
Old 04-10-2009, 08:02 PM   #9
Meteorite_Marty
Purchase the foglight stalk, I don't think the default headlight stalk can handle fog light control. The install is SOOOOOO much simpler and no messing with firewall and interior wiring. Plus, the fog light stalk is how it would come if you ordered your car with fogs from Toyota factory directly.
Old 04-10-2009, 12:27 PM   #10
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
How do you know I know if I have a fog light switch equipped stalk?
cyberfrogg is offline   Reply With Quote
Old 04-10-2009, 12:31 PM   #11
It will have a thin rotating band with the fog light symbol, besides the wide rotating end for the head and parking lights.
Speakers wires : how to identify + and - ? hystria In Car Entertainment + Electronics (audio / video / alarm) 23 05-27-2017 10:43 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Installing a remote starter without cutting factory wires? yaris08ce In Car Entertainment + Electronics (audio / video / alarm) 36 04-23-2009 08:59 PM
Ground Wires dngz Performance Modifications 8 11-26-2006 11:54 PM
Q about Routing wires to the engine compartment W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 10 11-01-2006 07:36 PM
