#1 | |
#2 | |
So, you are definitely correct that the stalk is not required, but the relay in that position, or the external relay wired through that position would be required. The kit that I bought included an external relay, so I wired the indicator directly to the combination meter. Here is the EWD for the fogs, which shows pin 3 and 4 on the upper left. The Fog light relay (at D46) is at the upper right. Its output feeds the fog lights and the combination meter indicator (center).
the diagrames above is for useing the switch supplied with the kit .
if you want to use the factory combo switch all you need is the relay (factory , or aftermarket) to plug into factory position as per diagrames. |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
So, let's see if I understand this. If I wanted to use the factory stalk instead of the little button that goes into the console, then all I need to do is wire up the fog lights, put the wire into the fuse box in the engine bay, and then put the relay where it's supposed to go? So I wouldn't even need that extra wiring harness for the cabin? If so, that's fantastic.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#5 | |
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
Purchase the foglight stalk. The install is SOOOOOO much simpler and no messing with firewall and interior wiring. Plus, the fog light stalk is how it would come if you ordered your car with fogs from Toyota factory directly. |
#6 | |
#7 | |
#8 | |
http://www.yarisworld.com/forums/sho...og+light+stalk |
| Speakers wires : how to identify + and - ? | hystria | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 05-27-2017 10:43 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
| Installing a remote starter without cutting factory wires? | yaris08ce | In Car Entertainment + Electronics (audio / video / alarm) | 36 | 04-23-2009 08:59 PM |
| Ground Wires | dngz | Performance Modifications | 8 | 11-26-2006 11:54 PM |
| Q about Routing wires to the engine compartment | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 11-01-2006 07:36 PM |
