Old 04-10-2009, 12:56 PM   #1
Originally Posted by cyberfrogg View Post
what do you mean they should theoretically not be switched? I'm sorry, I'm a noob at all this..
Could I just connect one of the wires to Pin 7 of the D2 connector on the combination meter like you said?
Pins 3 and 4 are the input / output of the fog switch, so without the switch I am not sure whether they are left to float or what (I'd go out and put a meter on there to find out for sure, but I am in the middle of packing for vacation).
Actually, looking back up at what 1NZ posted, when you are using the console switch, it gets connected across pins 3 and 4, so it acts the same as the stalk switch. The key is that the OEM pin 3 wire is pulled from the stalk connector and the console fog light switch inserts between the OEM pin 3 wire and the connector. Pin 4 does not get touched or connected to on the connector.
If you just "tapped" your switch onto pins 3 and 4 then that would explain the issue you are having.
Old 04-10-2009, 01:12 PM   #2
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
what does that mean? If I just "tapped" them?
cyberfrogg is offline   Reply With Quote
Old 04-10-2009, 01:19 PM   #3
I mean if you spliced your wires onto the existing wires, as opposed to pulling the pin out of pin 3 and inserting the new wire into pin 3.
Speakers wires : how to identify + and - ? hystria In Car Entertainment + Electronics (audio / video / alarm) 23 05-27-2017 10:43 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Installing a remote starter without cutting factory wires? yaris08ce In Car Entertainment + Electronics (audio / video / alarm) 36 04-23-2009 08:59 PM
Ground Wires dngz Performance Modifications 8 11-26-2006 11:54 PM
Q about Routing wires to the engine compartment W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 10 11-01-2006 07:36 PM
