Old 05-20-2009, 10:16 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
flickering due to day time running light.. u have to use a relay and direct connect to battery instead..hid needs 12v not 10..
FYI, toyota DRL runs on 12v, with a current (amperage) limiter.
to OP: you need one of these.
http://shop.ebay.ca/?_from=R40&_trks...All-Categories
Old 05-20-2009, 11:11 AM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
sorry bro i checked the voltage on drl its around 10v only if i turn the headlights on then its around 12v even 14v if the engine is running. voltmeter could be wrong though.
Old 05-20-2009, 06:32 PM   #3
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
Yaris here on Puerto Rico doesn't have DRL. However I check were is supposed to be and there's nothing.
Yaris_PR is offline   Reply With Quote
Old 05-20-2009, 09:20 PM   #4
IllusionX
If you did it on the yaris, then you are PROBABLY right. It wasn't the case when i had the echo.
I took no chance, and installed my HID with a relay right away on the yaris.
Old 05-20-2009, 09:27 PM   #5
Yaris_PR
Yaris_PR's Avatar
Well I'm going to buy that HID relay kit to avoid any problems...thanks everyone
Where is my DRL Module......? Help With HID's The Architect DIY / Maintenance / Service 6 05-20-2009 10:21 AM
DRL Disabled If I Install HIDs? darkmoon87 Cosmetic Modifications (Exterior/Interior) 8 02-26-2009 09:34 AM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 03:30 PM
Help with HIDs!!!! elsteverino889 Cosmetic Modifications (Exterior/Interior) 9 04-17-2007 12:02 PM
NEW HIDS 10000k!!!!!! elsteverino889 Cosmetic Modifications (Exterior/Interior) 69 01-26-2007 12:12 PM
