Old 06-30-2009, 11:36 PM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Sounds like you are rubbing on the guard , try Tamago's washer idea
on the bottom bolt's of the hub spacer's or machine your hub spacer's with -1.deg camber
Old 08-01-2009, 02:25 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
I never would have believed something as simple as two little washers would have such a big impact! The rubbing is gone!
Aftermarket exhaust systems that do not rub on the road! fuji Performance Modifications 10 04-28-2009 06:22 AM
Does +43mm rub? Split Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 02-28-2009 07:39 PM
New Wheels and TRD springs tires rub gmodder Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-25-2009 11:21 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Ruba a dub dub in the rear slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2007 08:27 PM
