Old 06-28-2010, 02:06 PM   #18
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
When you go changing around manifolds, you're likely to change the resonant frequency at which you get the optimum "ram" effect of the intake pulsations producing a positive pressure at the intake valve near closing, which gives you a bit of free "supercharging." The stock engine with the stock manifold has its torque peak at 4200 RPM, but has an amazingly flat torque curve across the whole band. You might end up getting a higher peak, but lose torque in the midrange and lose performance overall.
So your opinion is to leave it stock?
My intension is that I want an intake that produces more torque and power above 4500rpm compared to the stock one. I am aware I might loose low to mid range efficiency but that isn't important for my car as its not my daily car anyway.
To Bluevitz.... are you sure it is way out? How did you conclude that? visual estimate?
Parmas is offline   Reply With Quote
manifold 1zz to 1NZ? Nets Performance Modifications 3 05-09-2010 12:22 PM
1ZZ-FE Manifold Swap Bluevitz-rs Performance Modifications 12 04-21-2010 09:00 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Matrix 1.8 intake manifold dallas Performance Modifications 4 03-28-2009 01:42 AM
