Originally Posted by Bladerunner
Hi CTScott
I have read your help articles with great interest. They are fantastic. With reguard to my situation, I forgot to mention this cruise control is not for a Yaris. It's for a Toyota Blade which is very similar to the Auris or Corolla Hatch. The part numbers are identicle. If you go to the supplied link http://www.toyotaownersclub.com/foru...howtopic=86751 you will notice that there are three plugs. My problem is that in my case. the right hand plug exists but there are no pins inside. Do you know whether it is possible to add them. As I explained earlier, the instrument panel has the "cruise" light but at this stage I am not sure if the cable from the back of the clock spring to the ECM exists or if it's possible to add it.
I have no familiarity with the blade, but looking at that thread, the horn is connected through one of the other two connectors, so the 4 pin one is just for cruise. As for checking the rest of the wiring, you'd need to located the wiring diagrams for the blade to verify what is what. If you open the steering column cover, you will see the other end of the spiral cable connectors. If you count the wires connected within the wheel and then count the ones coming out on the other side, if there are two extras down below (and they are connected to two wires that disappear into the dash) then you are probably pre-wired.
