Old 12-12-2010, 08:26 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by Parmas View Post
The problem is about sure that is a software issue but we need Haltech support to solve it before we continue.... sooo the car goes back again into my fu..ing garage.
If haltech will not solve it within the next month I have no choice but to make custom triggering wheels for the crank and the cam using Haltech Hall Effect sensors.
I hope this would be the last issue as I am really pissed of about this engine and it is making me sick.
they (haltec), may have told u this already, the crank trigger settings are the same as the scion tc (they flew to our shop to create basemap on our dyno). are you using the sport 1000 or sprint 500? if you ever run into the issue of accelerating hard thru the gears and then the car hits a "cut", pm me and ill tell u the fix, has to do with the crank trigger voltage and filter settings.
cool build!
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 12-13-2010, 08:19 AM   #2
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
cool build!
Hi man, the issue wasn't the triggering but the ignition modules. Haltech replaced them with built in ignitor coils and worked like a charm.
Now I am tuning the engine myself and till now I done mapping of the engine with 9psi boost and 5000rpm [with AFR LOW 14 / HI 10.5 (boost) ]. This week I am preparing the car for the final tune which is the 2ZZ intake. If all goes fine, I have to retune the engine for the larger o/d of the 2ZZ intake Throttle Body (70mm) and runners
Old 12-13-2010, 07:15 PM   #3
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
sweet, love that haltec software i bet. It is really nice. That 70mm throttle body should open up a lot of power.
Ptuning.com
Old 12-15-2010, 04:15 AM   #4
Parmas
Parmas's Avatar
After my experience with this unit, I can say it is worth the money and since now I seen no issues with it. Solid rock ecu, full of description on all option tabs ( a must for beginners ) and reliable performance. Also to consider that it is good for almost any engine and features latest cam control technology + stock sensor compatability.
I am no expert on tuning, and with this unit I was capable to tune a reliable 9psi boost till 5000rpm (at least for now :) )
I am hoping better response with this intake. Let's be straight, If any would tell you what do you prefer between a custom intake or a Toyota proven one, I vote for Toyota and here it is!
I hope it will be ready for a christmas present to my self
Old 12-15-2010, 12:02 PM   #5
cdydjded
Drives: Yaris LB Turbo
Can you explained to me what is your logic on using a manifold from an engine that is 1.8 liters & revs 8000rpm on a 1.5 liter that revs 6300rpm? Are you aware that intake manifolds are designed to work within a specific RPM range? I dont get why you would think that the factory manifold from the 2ZZ would be a manifold than a custom one engineered to work for a specific engine combination.
cdydjded is offline   Reply With Quote
Old 12-15-2010, 05:11 PM   #6
Parmas
Parmas's Avatar
Originally Posted by cdydjded View Post
1. Can you explain to me what is your logic on using a manifold from an engine that is 1.8 liters & revs 8000rpm on a 1.5 liter that revs 6300rpm?
2. Are you aware that intake manifolds are designed to work within a specific RPM range?
3. I dont get why you would think that the factory manifold from the 2ZZ would be a better manifold than a custom one engineered to work for a specific engine combination.
1. I am no expert in intake manifolds but I am sure this manifold will definetly show more gains than the stock one. Since it was used on a 1.8L engine which revs 8000rpm it will surely be a plus with a 1.5L turbo engine.
2. I am sure it is the case, but who cares now that I am turbocharged. The stock intake wasn't designed to be used with forced induction.
3. The only answer for this is the price. The 2ZZ manifold + 2ZZ TB cost me half or lower than a quoted custom intake manifold only!
Old 12-15-2010, 07:12 PM   #7
cdydjded
1)Again you yourself admit no expertise on intake manifolds. So your logic makes no sense. You are going to waste your time & money.
2)You are correct about the stock manifold, but no one has reached the max limits of it. And the 2zz was also never designed for boost.
3)You will never get anywhere by cutting corners, especially price. Cheaper is never better. There are many reasons custom intake manifold are expensive.
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
