#1 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Ptuning.com |
#2 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I am no expert on tuning, and with this unit I was capable to tune a reliable 9psi boost till 5000rpm (at least for now :) ) I am hoping better response with this intake. Let's be straight, If any would tell you what do you prefer between a custom intake or a Toyota proven one, I vote for Toyota and here it is! ![]() I hope it will be ready for a christmas present to my self
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Can you explained to me what is your logic on using a manifold from an engine that is 1.8 liters & revs 8000rpm on a 1.5 liter that revs 6300rpm? Are you aware that intake manifolds are designed to work within a specific RPM range? I dont get why you would think that the factory manifold from the 2ZZ would be a manifold than a custom one engineered to work for a specific engine combination.
#4 | |
2. I am sure it is the case, but who cares now that I am turbocharged. The stock intake wasn't designed to be used with forced induction. 3. The only answer for this is the price. The 2ZZ manifold + 2ZZ TB cost me half or lower than a quoted custom intake manifold only! |
#5 | |
2)You are correct about the stock manifold, but no one has reached the max limits of it. And the 2zz was also never designed for boost. 3)You will never get anywhere by cutting corners, especially price. Cheaper is never better. There are many reasons custom intake manifold are expensive. |
#6 | |
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
