Old 05-26-2011, 02:44 PM   #1
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
The last guy that installed the filter must've not only torqued it with a filter wrench, but he probably also failed to oil the rubber seal and tread before installing.
A 64mm cap wrench (about $10 at any auto part store) definitely breaks it loose quickly. Just be sure you got the drain pan directly underneath because it will spill a little as you loosen it. It'll spill more if it drops.
Old 05-26-2011, 05:40 PM   #2
YarisLover09
Drives: 2009 Yaris Hatchback
Thanks everybody for your quick responses. I was working on it this morning and took a break until just now. I'm thinking of a couple options
This is one option I'm thinking of... I'm sure it would come in handy in the future and I'm looking at a couple that would match the ridges on the firestone filter
Originally Posted by jambo101 View Post
Screwdrivers may have worked as a last resort back in the day filters were made of sterner stuff,todays filter casing is on par with paper and putting a screwdriver through it will just rip it to shreds and leave you with chiseling whats left to get it off, if the filter is on so tight that you will tear it up trying to get it off why not just let the local oil change shop do the first oil/filter change and tell the guy not to put the filter on too tight.
This is the other thing.... Maybe for just this one I'll have my local shop do it. My car used to be a rental so I have no idea what they may have done, probably not oiled the seal, maybe they tightened it way too much. After I get the initial change I should be able to get it off next time (hopefully)
What does everybody use for filters, I'm thinking of Wix seems like pretty good for the price.
YarisLover09 is offline   Reply With Quote
Old 05-26-2011, 07:00 PM   #3
SilverBack
Joey
SilverBack's Avatar
I honestly assumed all filters had the same ridges to fit its' matching-sized cap wrench. If that's not true then I would opt for the clamp wrench instead just in case.
Old 05-26-2011, 08:51 PM   #4
YarisLover09
Yeah I think they are different.. The set that I was looking at should be pictured below. The one that looks like it would fit mine is the one at the 9' o clock position.
Yeah I have this mechanic that is pretty good down the street, they looked over my car before I bought it and pointed out a couple things (air filter + radiator replacement) that I needed to get fixed before I bought the car. So from what I can tell they are a pretty good place, I'm debating having them do it so I don't make a mess of things but make sure to ask them not to ratchet it on too tight. I've only put about 2,000 miles on the Yaris since I bought it but I'd rather err on the side of caution with replacing the oil because they didn't have a record of when it was changed. The oil does look pretty clean, still a light-amber color but for the price I figure why not get it done.
Old 06-02-2011, 08:57 AM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Go pay $20 for a cheap oil change then once you get home change the oil a filter to your preferred products..
Planning first oil change @ 500 or 1000mi schleppy DIY / Maintenance / Service 39 07-09-2010 06:28 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
