Old 05-26-2011, 05:40 PM   #12
YarisLover09
Drives: 2009 Yaris Hatchback
Thanks everybody for your quick responses. I was working on it this morning and took a break until just now. I'm thinking of a couple options
Originally Posted by SilverBack View Post
The last guy that installed the filter must've not only torqued it with a filter wrench, but he probably also failed to oil the rubber seal and tread before installing.
A 64mm cap wrench (about $10 at any auto part store) definitely breaks it loose quickly. Just be sure you got the drain pan directly underneath because it will spill a little as you loosen it. It'll spill more if it drops.
This is one option I'm thinking of... I'm sure it would come in handy in the future and I'm looking at a couple that would match the ridges on the firestone filter
Originally Posted by jambo101 View Post
Screwdrivers may have worked as a last resort back in the day filters were made of sterner stuff,todays filter casing is on par with paper and putting a screwdriver through it will just rip it to shreds and leave you with chiseling whats left to get it off, if the filter is on so tight that you will tear it up trying to get it off why not just let the local oil change shop do the first oil/filter change and tell the guy not to put the filter on too tight.
This is the other thing.... Maybe for just this one I'll have my local shop do it. My car used to be a rental so I have no idea what they may have done, probably not oiled the seal, maybe they tightened it way too much. After I get the initial change I should be able to get it off next time (hopefully)
What does everybody use for filters, I'm thinking of Wix seems like pretty good for the price.
YarisLover09 is offline   Reply With Quote
Planning first oil change @ 500 or 1000mi schleppy DIY / Maintenance / Service 39 07-09-2010 06:28 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
