Old 05-26-2011, 02:44 PM   #11
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
The last guy that installed the filter must've not only torqued it with a filter wrench, but he probably also failed to oil the rubber seal and tread before installing.
A 64mm cap wrench (about $10 at any auto part store) definitely breaks it loose quickly. Just be sure you got the drain pan directly underneath because it will spill a little as you loosen it. It'll spill more if it drops.
Planning first oil change @ 500 or 1000mi schleppy DIY / Maintenance / Service 39 07-09-2010 06:28 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
