Roadrunner Jr.
Out of curiosity, why would a battery help if it's not making the vehicle's power after it starts?
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
The battery is basically a capacitor once the car is running. It keeps the voltage from sagging too far if the alternator can't source enough current. The problem is that the stock battery and alternator combo are sized for just the standard load. If you run equipment that draws more than stock, you will find that after starting the battery will take a few minutes or so to get back to a full charge.
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Raising Idle speed? | Incillio1 | General Yaris / Vitz Discussion | 20 | 05-10-2020 02:08 PM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| Exhaust Pipe Size (Tamaño del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
