#25 | |
The service you get is only as good as the place you take it, and I would be suspect of any place that said they lubed a belt. A number of things could cause a belt to fail or come off... A piece of debris from the road kicked up, if the water pump was going and had excess end play. I lost one when our aluminum crank pulley (not stock) split in two. Bad stuff happens to cars. I would love to see a pic of an almost snapped off clutch. How does that happen, and what is it almost snapped off of? I don't know of any service inspection that checks a clutch, hard to see it without pulling the trans. Seems like there is more to this. I have a 2001 Expedition with 199450 miles on it, and a 2007 with 40k, guess which one has spent more time at the dealer. Its the newer one. Sometimes your are lucky with a car, others times, not so much.
| Shorter Serpentine Belt? | The Architect | Performance Modifications | 6 | 04-20-2021 10:42 AM |
| anyone has a DIY change serpentine belt on yaris sedan | rufnnek | DIY / Maintenance / Service | 0 | 06-16-2011 06:15 AM |
| Serpentine belt broken with oil on it | HerYarisNotMine | DIY / Maintenance / Service | 10 | 05-31-2011 02:51 PM |
| serpentine belt for 2007 yaris hatchback | nikki9 | DIY / Maintenance / Service | 4 | 04-09-2011 09:22 AM |
| serpentine belt 1.3 engine | `psycho | DIY / Maintenance / Service | 2 | 04-08-2011 10:40 PM |
