Old 01-02-2012, 02:03 PM   #4
Iggy888
Iggy888's Avatar
Drives: 2008 5 Door Liftback
Originally Posted by yojabbajabba View Post
Do you think it'd be possible to attach a second set of controls on my steering wheel (on the oppposite side to where they are now) to control the bluetooth Push-to-talk functions of my new head-unit?
Yes, that is what I have done.
The part number I listed earlier is switch controls for both sides of the steering wheel:
Toyota Name: 84250A STEERING PAD SWITCH ASSY.
Toyota Part #: 84250-52010-C0
Note: The last two digits of the part number indicate the colour:
B0 = Silver
C0 = Black
Left side controls = Volume Up/Down, Mode and Seek Up/Down
Ride side controls = Push to Talk, Answer Phone, Hang Up phone
The diagram below shows how both controls are wired together and connect together into one plug that attaches to the top of the spiral cable assembly (clock spring):
I see that you have listed parts above, are they compatible with both sides? and will this affect the airbag mechanism?
The switches will work provided the steering pad cover (air bag) has room for the switches on either side.
If you currently have a narrow steering pad cover (air bag) like the one pictured below then you can add the switches:
However, if your steering pad cover (air bag) is wider like the one below then there is no room for the switches:
My car had the wide air bag cover so I had to replace the whole air bag too
Though people sell the narrow steering pad covers on eBay, the steering pad cover is riveted to the air bag.
Drilling into an explosive airbag charge to swap covers did not seem like a good idea
Iggy888 is offline   Reply With Quote
SoCal Nardi Steering Wheel 330mm DuckinOut Items for Sale by private party 5 05-23-2009 10:25 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
steering wheel outta control when im coming to a stop dinamix Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-18-2009 10:16 AM
audio volume control on steering wheel hans_fh In Car Entertainment + Electronics (audio / video / alarm) 18 01-04-2009 09:07 PM
