Old 01-03-2012, 01:14 AM   #5
yojabbajabba
Drives: 2008 YRS 5Dr LB (1.5L)
First of all, thanks for the reply!
Originally Posted by Iggy888 View Post
Yes, that is what I have done.
The part number I listed earlier is switch controls for both sides of the steering wheel:
Toyota Name: 84250A STEERING PAD SWITCH ASSY.
Toyota Part #: 84250-52010-C0
Note: The last two digits of the part number indicate the colour:
B0 = Silver
C0 = Black
Left side controls = Volume Up/Down, Mode and Seek Up/Down
Ride side controls = Push to Talk, Answer Phone, Hang Up phone
- Is there a part that only has the PTT/Answer/Hang Up assembly? I already have the smaller steering cover + vol. controls, and by a quick google search, I have found that the part costs approx. $130 USD? Is that reasonable? (And, where do you source your parts? Local Dealership? Online vendors?)
Also,
The diagram below shows how both controls are wired together and connect together into one plug that attaches to the top of the spiral cable assembly (clock spring):
Attachment 45020
The switches will work provided the steering pad cover (air bag) has room for the switches on either side.
If you currently have a narrow steering pad cover (air bag) like the one pictured below then you can add the switches:
Attachment 45022
However, if your steering pad cover (air bag) is wider like the one below then there is no room for the switches:
Attachment 45024
- Since I already have my vol. controls on the wheel, does that mean the spiral cable is there already for me to plug in the bluetooth control assembly?
Finally, can you please inform me on what wires go from the ASWC to the Bluetooth functions also?
And thank you for the tip re: NOT drilling the steering wheel. Duly noted. :)
yojabbajabba is offline   Reply With Quote
SoCal Nardi Steering Wheel 330mm DuckinOut Items for Sale by private party 5 05-23-2009 10:25 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
steering wheel outta control when im coming to a stop dinamix Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-18-2009 10:16 AM
audio volume control on steering wheel hans_fh In Car Entertainment + Electronics (audio / video / alarm) 18 01-04-2009 09:07 PM
