Old 01-16-2012, 05:30 AM   #7
yojabbajabba
Drives: 2008 YRS 5Dr LB (1.5L)
Back again Iggy!
I have received my ASWC, and the harnesses necessary for my new head unit (which I'm picking up on Wednesday - Alpine CDE 133 BT). This is a good things, as it means I can now proceed to doing all preparation wring :D
So, here are my troubleshooting questions.
Connecting the ASWC harness to D74:
"5. Connect Pin 6: SWG (ground) on Connector D74 to ground"
Does that mean I have to cut off Pin 6 and re-wire it to the Ground used in "1."?
Connecting the ASWC harness to D74 (general)
- When "tapping" wires, does this literally mean joining the wires from the ASWC in-line with the wires on D74 - i.e. stripping off a part of the insulation on the respective wires, and then soldering the ASWC wires in-line? I'd like to avoid cutting off the OEM harness connector.
That's about it for now,
Thank you for your help!
Aaron
yojabbajabba is offline   Reply With Quote
SoCal Nardi Steering Wheel 330mm DuckinOut Items for Sale by private party 5 05-23-2009 10:25 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
steering wheel outta control when im coming to a stop dinamix Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-18-2009 10:16 AM
audio volume control on steering wheel hans_fh In Car Entertainment + Electronics (audio / video / alarm) 18 01-04-2009 09:07 PM
