Old 05-05-2012, 02:49 AM   #1
wrk13s
Drives: 2006
Look at the "Fuel" section of the service manual (posted at the top of the DIY section) for info on how to remove the fuel sender. The fuel filter is the plastic mesh thing clipped to the bottom of the fuel pump in the picture below. It is removable and replaceable. The hardest part of the whole process is removing the cover of the fuel tank. Is is screwed on mighty tight and I didn't have the spanner tool, so I used a dead-blow hammer and a piece of oak to spin it off. However you remove it, avoid the use of ferrous metal tools to prevent sparks.
Attachment 39578
Attachment 39579
hi thanks for this info on the fuel filter but i can not find the service manual you are talking about can you please help.?
wrk13s is offline   Reply With Quote
Old 05-06-2012, 08:48 PM   #2
http://www.microimageonline.com/foru...32-YARIS-FILES
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Replacing fuel filter duke_afterdeath Middle East 28 07-12-2010 04:26 AM
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 11:40 AM
